![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 - Oil cooler or just the gasket? |
Replace it as you don't want to do the job twice. 2012 TDV8 Vogue (L322) |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
aiye can only agree with above. its 150quid from advancedfactors.
NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 85 ![]() ![]() ![]() |
Just found this thread: https://www.fullfatrr.com/forum/topic61909...p;start=15
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
A much easier home job on the 322 compared with the 405... But if that AF price is correct? Seams a no brainer... Just be careful of the small thin brittle coolant lines! Or better still, factor in replacing them... That's what id do... |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 773 ![]() ![]() ![]() |
After 18 months and 20k miles, I'm still bucking the trend having changed only the gaskets. No issues and everything is still completely dry. |
I'm >30k miles after just having the gaskets done. 2012 TDV8 Vogue (L322) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
Think my oil cooler had warped when mine was done….. 1 week into ownership in Jan 2016….
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 ![]() ![]() ![]() |
I’ll chuck my twopennyworth in……the job is roughly 4-5 hours labour, do the oil cooler & forget it. You may get away with gaskets….but…..if it leaks again, that’s another 4-5 hours labour. Just sayin 😜 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
Get the one from Advanced. Fit and forget.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
I just replaced the gaskets on mine. No problem. The cooler was absolutely fine and there was no need to replace it. Kev
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 749 ![]() ![]() |
I reckon it just depends on who is doing the job, if you're doing yourself (no labour cost) then it might be worth just doing the gasket, if you're paying full price to get it done then it makes sense to replace the cooler, |
id say opposite.
"nothing more annoying than doing a job twice haha"
haha touche sir.
