Home > My Range Rover > Newbie looking for a FFRR!
Page 1 of 4 1234>
hogesar
Hi all,
I may be doing a rubbish job of searching on here, but I'm currently on the lookout for a FF Range Rover, settled on the 4.4 V8 - Ideally 2011/12.
I'll be moving on from my Jag XF S Portfolio 2012 which appears to have quite a lot of bits shared with the RR.
I couldn't choose between the RR Sport and the Full RR until I sat in both. My mind is made up and I still don't really know why!
I have a fairly limited budget for the market, I think. I want to keep a couple of grand to one side expecting to have to do some bits. I'm not sure if I should go Dealer - Warranty or Private - Lesser price, save some more behind. Most warranties try and get out of doing anything anyway...
I'm looking to spend around £11k. Maybe max £13k for the right one. That still gives me something in the back pocket.
Should I be overly concerned about mileage? I've always been far more focused on condition. My Jag has done 126k on the 3.0 v6 diesel and i've had cambelt, pump, inlet manifolds done in my time. But the engine doesn't miss a beat.
Is the 4.4 known to be fine with high mileage? I won't actually do many miles a year - 8k probably.
Any help / advice / pointers in the right direction would be much appreciated!
Post #670963 11th Aug 2023 9:29am
DrRob
4.4 TDV8 diesel? They don't like short journeys so you're aware. DPF will bite you Whistle Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #670968 11th Aug 2023 9:48am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
On milage: @LandyManSam has one with over 200k & still going strong…. Check out his channel https://youtube.com/@SamsMotors
I got mine with 67k and little history and have had to do a lot of “catch up” maintenance….. thank goodness for Glenrands at Liphook ! TDV8 4.4 2012
Post #670969 11th Aug 2023 9:56am
hogesar
Thanks. I figured as much. This won't really be used for REALLY short journeys. Even my 15 mile work commute which is short, does involve mostly dual-carriageway which has kept the DPF issues at bay for my Jag, hoping the same for the RR?
Post #670971 11th Aug 2023 10:11am
hogesar
Thank you for the link!
Post #670972 11th Aug 2023 10:11am
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Good luck with the search! Your budget looks ok, but I think you'll probably have to look at quite a few to find a sweet one. Rust and lack of maintenance are the main problems, even ones with FLRSH will probably require 'catch up' maintenance on things like gearbox fluid/filter, diff and transfer case oils, belts, pullies and tensioners when the mileage is up around 100,000.
There's a good video on rust inspection points here:
https://www.fullfatrr.com/forum/topic67536.html
Maintenance can be caught up with, hopefully without major issues assuming the mileage isn't intergalactic, but if the rust is bad it will be major ££ to sort out. I'd hold out for long enough to find one with minimal rust, they are out there.
Buyer's guide thread in the wiki is useful:
https://www.fullfatrr.com/forum/post189410.html#189410
I also put a checklist together when I was looking for my 4.2 supercharged:
https://www.fullfatrr.com/forum/topic52603-15.html
fanders
Thumbs Up ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #670974 11th Aug 2023 11:12am
hogesar
Thanks fanders, a lot of weekend reading / watching for me!
Mega helpful, thanks a bunch!
Post #670976 11th Aug 2023 12:28pm
JayGee
Ignore service history and just get it checked over by a specialist before you buy. JLR's oil change interval is too long to be an indicator it's been properly cared for. Best buy from an enthusiast here who has looked after it properly..... 2012 TDV8 Vogue (L322)
Post #670994 11th Aug 2023 4:26pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
Take a lookat the for sale section on here. I think a member still has a 2012 tdv8 for sale and he has spent a lot on it.
The right one will come up. Check Auotrader too. I wouldn't worry about buying from a dealer as the warranty will be short given the age. Extending it will be costly. Look at condition and recent history of maintenance and preventative work. There are loved ones out there.
Post #671007 11th Aug 2023 9:17pm
DrRob
3.6 with digital dash. It’s what I’d go for in hindsight. No DPF. Blank the EGRs. Remap and it’ll be a perfect motor. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #671014 12th Aug 2023 8:02am
JayGee
What's the price? I'd still steer clear of the 3.6 due to it's weak turbo's and gearbox. In hindsight I don't regret spending the extra on a 4.4. 2012 TDV8 Vogue (L322)
Post #671015 12th Aug 2023 8:47am
hogesar
I couldn't find it, although probably me being dumb!
Post #671020 12th Aug 2023 10:30am
hogesar
Yeah I think I'm pretty set on the 4.4 having done a few days combined reading and YouTube videos!
Post #671021 12th Aug 2023 10:31am
mjdronfield
Lower down on the Home page…
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #671023 12th Aug 2023 10:55am
hogesar
Apologies I found the sub forum just not the listing being mentioned haha
Post #671024 12th Aug 2023 10:56am
Page 1 of 4 1234>
