Home > Maintenance & Mods (L322) > Venture cam retro fitting
Cudman
2011 Range Rover Supercharged 5.0 SC V8 Bournville
Hello Philcorsa, I'm in your position now as I have the docking station and Venture cam. My RR Vogue MY08 did not come with a docking station so I plan to retrofit the docking station and enable it using my IIDtool. Hos much of the glovebox trim did you take away to fit the docking station?
Your photos show the cabling but not how you fitted the station. Do you have more details of the fitting, cut outs etc?
Post #511220 7th Apr 2019 1:41pm
philcorsa
France 2008 Range Rover Vogue TDV8 Buckingham Blue
hello
yes you have to cut a part of the glovebox, but it's really easy
the most annoying thing is to dismantle the dashboard
good luck RR L322 4.4 TDV8 Vogue
RR L322 3.6TDV8 Vogue
Disco TD5 HSE
RR P38 4.6 HSE v8 GPL
Disco 3.9 V8 GPL
Disco 3.5 V8 GPL
RR 300TDI
RR 2.4 VM TDI
Land Commando
Post #511494 9th Apr 2019 6:52pm
Cudman
So, I took the leap and removed the upper glovebox and installed the Venturecam dockingstation. For others benefit I attach some pictures on the hole that needs to be installed in the upper glovebox to fit the venturecam.
This is what the glovebox looks like when it has been removed.
The area of the upper glovebox where the hole shall be.
The hole is now installed in its right position.
Docking station fitted. Note that on my docking station there were two flanges at the bottom that may likely fit into some hole when fitted originally, however I just removed the flanges and pressed the docking station home into the glovebox, mating perfectly with the hole for the connectors.
And the final product, docking station installed, CCF updated to enable "Companion cam dock installed", "Venturecam installed", two Venturecam batteries replaced and the cams successfully synched with the station later.
EDIT: Have a docking station for sale for L322 2004-2006 (where the docking station fits under the steering wheel) as I purchased one not knowing the different fitting based on year. PM for price and shipping.
Post #514893 10th May 2019 3:43pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Apologies for resurrecting an old thread;
I'm intending fitting a venture cam to a 2010 L322 which has surround cameras. I wondered if anyone, particularly those who have done a retrofit might know the following please?
* Is there any link / commonality with surround cameras? (Im thinking not)
* Do all vehicles have the loom with plug C2685 on it? (2 x 4 pins behind the passenger side of the dash)
* Do all vehicles have the loom with plug C2703 on it? (which I believe might be similar to a co-ax plug and connects at the other end to the touchscreen) or;
* On later vehicles is C2703 in fact used or does the camera link directly to the car?
Many thanks in advance for any info!
Richard 2010 Range Rover Autobiography TDV8 Santorini Black
2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone]
2003 Range Rover HSE Oslo Blue [Gone]
1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone]
1990 Camel Trophy 127 (Workshop Vehicle) [Gone]
1989 Camel Trophy 110 (Workshop Vehicle) [Gone]
1998 Camel Trophy Freelander (South African Team Vehicle)
1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone]
Post #615531 9th Dec 2021 5:53pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I am also in the process of doing the same, had a venture can for years, just got a docking station and a battery to fit!
Thanks for the photos and guidance.
I ordered the battery from here, need to solder the wires and thermister, but under £9 delivered😉
https://www.vapextech.co.uk/7-2v-battery-p...pextech-rx Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #626755 22nd Mar 2022 9:37pm
Humpster
New Zealand
Hi, I just installed a Venture cam into my surround camera equipped 2011 4.4tdv8, easy install, camera has new battery and charging.......but how do I pair the camera to the car, do I need some coding of some sort, any help would be much appreciated
Post #670603 7th Aug 2023 2:07am
RJPotts
It needs to be enabled in the cars CCF file. If you have a GAP IID you can do that yourself, not sure what other platforms are suitable to do so.
You did get a 2010+ dock didn't you? If so, where from & are there any more available please?
Post #670633 7th Aug 2023 11:13am
Humpster
New Zealand
Thanks for the quick reply Richard. I'll ask my local network about modifications to the CFF files, Gap 11D.
Yes dock and camera was from a late 2010 Vogue 4.4TDV8. Car was freshly imported in near perfect condition with every option you could think off, but sadly the papers were not in order so MOT scrapped the car, such a crying shame. No other venture cams available...sorry.
Post #670687 7th Aug 2023 11:30pm
