Home > Technical (L322) > Stubborn front caliper carrier bolts
barbary
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
I need to replace a front disc but I can't remove the carrier bolts. Brand new 6 - point socket on a 24" breaker bar, with another 2ft of scaffolding pole. Slipping on the bolt head. Any suggestions how to get these out?
Post #670484 5th Aug 2023 12:08am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Maybe a bit of heat around the bolt …..I’m looking at doing mine this weekend
Post #670485 5th Aug 2023 3:37am
JayGee
Impact wrench will loosen seized bolts more effectivley than brute torque load. 2012 TDV8 Vogue (L322)
Post #670488 5th Aug 2023 7:06am
Rudyard1
It was only after buying my RR in 2019 did I soon discover that any tool in 3/8 form is worthless (snapped countless bits) and only 1/2 will stand the test of time. Also purchased a MAPP gas torch (much hotter flame than reg gas torch) and Plus Gas (dismantling fluid).
You can get plus gas from screw fix. Soak it in this and leave for a while and then get the torch on it. And good luck! 2007 Range Rover Vogue 3.6 TDV8
Post #670489 5th Aug 2023 7:45am
You could try using the weight of the car. Jack the front wheel up, take the wheel off, put your socket and breaker bar on the offending bolt with the end of the breaker bar on a piece of timber on the ground and then release the jack a couple of inches.
This will put a sustained load on the bolt that should crack it. Just leave it while you have a coffee or cut the grass or whatever. Thumbs Up
Post #670491 5th Aug 2023 8:04am
barbary
thanks, will try those suggestions
Post #670535 6th Aug 2023 12:46am
barbary
Ok, have tried heat, soaking in fluid, prolonged tension on the bolt, all to no avail. The bolt head is now well rounded, so conventional methods wont work now I think. My options are, weld a socket to the bolt, the additional heat may help. Or grind the head off the bolt. This latter would entail removing the caliper, carrier and disc as one unit, then drilling out the remains of the bolts. does this sound feasible?
Post #670676 7th Aug 2023 10:15pm
Think I'd take the whole hub off and take it to a lorry garage and ask them to use their 3/4inch rattle gun on it... Thumbs Up Pete
Post #670682 7th Aug 2023 11:31pm
garyRR
This is a shame but I do think you should have (and should) invested in a decent impact wrench and sockets. Another must for an L322. Impact wrenches work wonders at knocking stuck bolts un-done (although all of the above methods are also needed too).
There are some good cordless ones out there now with 1,000NM+.
There are also some very impressive cheap Chinese wheel hub guns knocking about such as the MPlus. 2015 Range Rover Autobiography 4.4 SDV8
Post #670684 8th Aug 2023 12:18am
Rudyard1
Must admit I agree with the above - I have a 3/8 Milwaukee stubby impact wrench and it’s been invaluable and with it being so small and powerful it can get behind discs/suspension arms/fiddly bits etc 2007 Range Rover Vogue 3.6 TDV8
Post #670691 8th Aug 2023 6:59am
JayGee
Heat the head up with a gas torch so it's softens, hammer on a 1/2 socket that's slightly smaller (maybe imperial) and then run a fully charged impact driver on it. Bolts and nuts seized by corrosion need shock waves to break this bond and not torque load. 2012 TDV8 Vogue (L322)
Post #670696 8th Aug 2023 8:43am
mgrover
I struggled with all sorts.
mates 1000nm impact wrench Censored through it Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #670701 8th Aug 2023 9:15am
Merchy
As JayGee said . soften head, hammer on a slightly smaller impact socket, and try an impact gun.
Do not use a standard socket, as these can 'explode' when used with a large capacity impact gun, it's an easy way to blind yourself.
Then if that fails, Haylands suggestion would be my next step. IF that failed then the hub is already off for cutting the bolt head, then drilling out the stud in a machine shop or similar.
Post #670723 8th Aug 2023 12:17pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Had the same problem. Tried impact guns etc. Welded on 6 nuts but all broke off. My mate used an arc welder and disparate metal rods to weld a nut on. Big breaker bar and scaffold pole released the bolt. I was amazed that the threads in the caliper were intact.
No idea why the bolt was so tight, very little corrosion.
Best careful of the brake hoses especially when using an angle grinder to clean the bolt before welding. Shocked 2007 3.6 TDV8
1979 Mini Special
1988 Yamaha FJ1200
!952 BSA Gold Flash
Post #670729 8th Aug 2023 1:41pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
And me. Milwaukee M18 Fuel 1/2in will get most stuff off. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #670736 8th Aug 2023 3:30pm
