Home > Technical (L322) > 'Thunk' from the back end - any ideas?
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Driving up the ramps in a multi-storey the other day, there was a disturbing 'thunk' from the back end. It only occurred swinging to the right and mildly accelerating up the steepish ramps, at exactly the same point on each of the three ramps. No issues before or since, it is fine on the road, and I have been unable to replicate the noise again on the road.
Last mot had advisory for worn rear subframe bushes, possible the subframe could be moving enough to cause such a noise in specific circumstances? Any thoughts appreciated.
Booked in with my local indie next week to see what they can find. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #670121 30th Jul 2023 6:57pm
Steve7678
United Kingdom 2006 Range Rover Vogue SE TDV8 Rimini Red
The subframe bushes can cause a thunk, they aren't hard to do if you've a press (search for x5 subframe bush removal), but get genuine bushes not aftermarket c.£80 each.
The aftermarket bushes are slightly smaller and tend to slip out and that's why some people put pins in to hold them.
Also the bushes are oval shaped and go in a specific orientation. I fitted mine 90degrees out the first time so I hard to refit the correct way.
Also look at the wishbone and hub bushes, there is a lot of pressure on them so they are hard to 'test'.
My bushes passed an MOT but I noticed one was splitting when I was swapping a wheel.
Post #670319 2nd Aug 2023 4:52pm
RR2B
Steve, thanks for the useful info. I still have not been able to replicate the 'thunk', as it's not convenient to return to the offending multi-storey! Seems to be a very specific set of circumstances that caused it. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #670386 3rd Aug 2023 4:59pm
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Sorry if this reply is a bit too obvious or just a stupid comment.... but, are you sure it wasn't something in the back shifting around? This has happened to me before.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #670525 5th Aug 2023 7:34pm
