Home > Maintenance & Mods (L322) > air suspension
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
air suspension
well going on from the last suspension issues (which was a flipped sensor) we were driving on Saturday when suddenly the car started to lift at the front and become very bouncy then within quick succession there was two load explosions and the front dropped to the bump stops Sad
managed to drive it back home but I'm assuming the air bags have blown, so having looked on-line it appears to be reasonably easy to replace the bags but I'm concerned that it will do the same once i install new ones, anyone have experience or tips?
Cheers
Post #670160 31st Jul 2023 3:37pm
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
Not exactly the same, but i think its an issue where the cars rarely used in wading/off road height.
I raised mine up to allow me to see more underneath about 1min into looking a loud bang and car dropped, scared the life out of me as i was almost underneath.
I think if the rubber isn't exercised they get perished in a certain spot then raising increases pressure and they let go on a crease. Mine had about an inch long split.
Difference being i intentionally raised mine, yours if i am right did it on its own, what speed were you doing? as if under 30mph could you have caught the button?
Failing that an incorrect ride height calibration and car thinks its lower than it was?
Post #670163 31st Jul 2023 3:55pm
Discofish
was actually stationary at traffic lights, but yes i think calibration might come in to it somewhere
Post #670166 31st Jul 2023 3:59pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
@Discofish
I replaced 2 front bags last summer from Island4x4 online and have had no issues with them since. A fairly easy and straightforward job, assuming you can get the struts off ok. Thumbs Up Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #670171 31st Jul 2023 4:24pm
Discofish
cheers,
the video on the internet was from the USA so didn't have the same rust/dirt issues as mine so those bolts just 'fell out' so know what you mean... did you do anything after reassembly (calibration etc?) or did it just settle on it's own?
Post #670201 1st Aug 2023 7:27am
grayst01
Hi, no calibration afterwards was required. We cycled thorough all height settings and the car found its level again. If you have the GAP IID tool calibration can be done anytime after if necessary. Cheers, Steven.
Post #670217 1st Aug 2023 9:14am
Discofish
bonus Thumbs Up
better get the penetrating spray on those bolts Laughing
Post #670219 1st Aug 2023 9:23am
grayst01
ha! Yes that would be very advisable… Big Cry Cheers, Steven.
Post #670220 1st Aug 2023 9:27am
