![]() | Home > Technical (L405) > rear end sliding |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
i've searched the forum and cant find anything similar to my problem..
did the first oil change solve your problem Nick? ... - .- -.
nickt68 Member Since: 05 Nov 2010 Location: Herts Posts: 99 ![]() ![]() |
Yes, big improvement straight away Stan but it has gradually come back, albeit not as bad, over the last few thousand miles. I'm hopeful that the next change should fix it for good! It's just an oil change this time and not the software update too |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
My L322 did that Stan and it turned out to be a rear hub bush. According to my Indy, it’s hard to find with a pry bar because they check it with all the weight of the car loaded on it, making it seem ok. Got - 2017 SDV8 Autobiography in Loire Blue
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8377 ![]() ![]() ![]() |
Could it be this Stan...
thats interesting Pete and although it refers to a judder rather than the sliding rear , it could solve my problem.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Hi Stan
i dont know Alex...how do i determine this?
Lots of ways to find out but you can do it this way from your seat...!!!
The Dealership had to get confirmation from technical at JLR to change the diff which the warranty company then approved,
didnt realise this info was on the build sheet Pete..
When you go to the screen 4x4 information it will show a padlock (or not).
Looks like you don't have a locking rear diff. You are back to the double flush and software update on the transfer box... |
Stan, when you checked the car on the ramp, did you only check the car with the suspension on full droop? |
