Home > Technical (L322) > Suspension woes |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1180 |
I would look at various factors, what mileage is on the car.
29th Jul 2023 4:30pm |
mjq07 Member Since: 05 Sep 2022 Location: Derbyshire Posts: 12 |
Thanks for the reply. The car has done 145k so pretty well run in, but apart from a knackered bushing on the arm it drives faultlessly. No evidence of misting on the shocks and despite the age I'm kind of tempted to just change the bag. But then it does make sense to keep on top of the preventative maintenance for peace of mind as I'd like to try to avoid being stranded whenever possible.
29th Jul 2023 5:12pm |
Site sponsors are a good start for spares, for instance I have used Advanced Factors and Duckworths, the added benefit is you can contact Advanced factors for instance and they will identify exactly the spares for your model / year etc and offer plenty of advice. If in stock, delivery tends to be very quick and reliable.
29th Jul 2023 5:43pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3195 |
Replacing parts just in case they fail can end up as a very expensive excercise. Certain components that require time consuming removal such as the anciliaries at the front of the engine could benefit from this but easy stuff to do like removing struts - just replace when broken. 2012 TDV8 Vogue (L322) |
29th Jul 2023 5:55pm |
