Home > General > No aircon = sweaty armpits!
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
So took a drive this afternoon to Peterborough down the A47. My aircon doesn't seem to be working. Had it re-gased a couple of weeks back at kwik fit. When I put the aircon on I can hear the fans kicking in but it's just not ice cold air that comes out. When I switch the aircon off the air gets colder???? But only slightly but enoughht to notice. Is my unit knackered? I just put it down to it needing a re-gas but obviously that's not it. Anybody had this before?
cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #66956 4th Jun 2011 4:59pm
SteveMFr
Site Sponsor
AC's are generally maintenance free. Refrigerant missing means leak. That means finding leak, fixing, and then charging the system. Re-gas is a rip-off. There ought to be a law against anyplace with kwik, jiffy, etc from touching anything other than air in the tires.
There is oil in the system as well (special oil, not 10w-40) and this leaks out with the refrigerant, so check the AC lines/condenser/compressor for 'damp' spots.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #66960 4th Jun 2011 5:23pm
Fox
I'd go to a proper garage first.
Kwikfit? Thud
Post #66962 4th Jun 2011 5:53pm
Ludzy
Kwikfit? Thud
Well I was at kwik fit trying to get my wheels aligned but that didnt happened so ended up just getting a re-gas. Ya get ya money back if the temp is less than 10% before. Just seems strange how the blowers are warmer when on normal rather than zircon?? Ex FFRR 4.2 Supercharged
Post #67001 4th Jun 2011 10:42pm
Ludzy
Well I've had a good check for leaks etc but cant find anything. Looks like I'll be booking it in. Ex FFRR 4.2 Supercharged
Post #67035 5th Jun 2011 11:04am
KwikFit
Re: No aircon = sweaty armpits!
[quote="Ludzy"]So took a drive this afternoon to Peterborough down the A47. My aircon doesn't seem to be working. Had it re-gased a couple of weeks back at kwik fit. When I put the aircon on I can hear the fans kicking in but it's just not ice cold air that comes out. When I switch the aircon off the air gets colder???? But only slightly but enoughht to notice. Is my unit knackered? I just put it down to it needing a re-gas but obviously that's not it. Anybody had this before?
cheers[/quote]
Hi Ludzy,
Please could you return to the Kwik Fit centre where you had to the re-charge - they should be able to help. Alternatively, you can PM us a phone number and we'll give you a call.
Regards,
Gerry
Post #67475 7th Jun 2011 4:12pm
dan_uk_1984
LOL! Really why would you do that!?
Last time I took a RR to KwiKFit for re-gas they emptied all the gas out and then tried to charge me. I said what about refilling, I had a 10 minute argument whether they had filled the system or not because the printout said emptied XYZ filled 0.
Then I went back for an MOT a few months later to be told my rear pads were below legal 1.5mm limit, when I questioned this they said they do a visual check. Argue followed again, how can you see in the dark whether a brake pad is 1.5mm or 2mm. They then said I couldn't take it away for a free re-test. I took it elsewhere for its MOT and pads, where it passed on the original pads, I took them out and showed KwikFit the 5mm pads and they refunded my MOT cost.
To summarise - they are a bunch of incompetent morons!
Post #67481 7th Jun 2011 4:35pm
Reformed
I have to agree with Dan, I have had issues with them in the past which is why I would never use them again for anything.
Quick Fit - Quickly fitted, quickly fell off again! Reformed
Post #67491 7th Jun 2011 5:47pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Or the inability to balance wheels! Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #67503 7th Jun 2011 6:28pm
Ludzy
Well the cars booked in on Thursday at my local jag indy. The reason I went kwik fit in the first place was because it was literally a minute drive away from my house. Never been fussed about aircon before just seems strange how air is colder on normal blower compared to aircon.
Also Gerry (kwikfit) thanks for msg. I may well be returning to kwikfit depending on what my indy says. Ex FFRR 4.2 Supercharged
Post #67596 7th Jun 2011 10:35pm
Ludzy
The condensor has 3 leaks. So a new condensor on order and £450 lighter! Ex FFRR 4.2 Supercharged
Post #67839 9th Jun 2011 10:34am
dan_uk_1984
Have you had the work done already? The part is less than £200 so that seems like a lot of labour?
Post #67840 9th Jun 2011 10:37am
Ludzy
No not done yet. Can't get it done until next Thursday. Not at home so can't check part numbers to get a price but was told about £450. Picking car up in about an hour so as soon as I'm home I'll check parts needed. Ex FFRR 4.2 Supercharged
Post #67850 9th Jun 2011 11:40am
