![]() | Home > Technical (L322) > Suspension problem |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
They are not measurements they are just values, they don't mean anything...... It tells you about them in the Gap IID manual... |
Tomc Member Since: 15 Oct 2020 Location: Belfast Posts: 37 ![]() ![]() ![]() |
Thank you. Just strange the value is not similar to the others. |
What faults caused you to need to calibrate it? 2012 TDV8 Vogue (L322) |
Vehicle would lower onto bump stops, warning would say max 30 mph. Then front of veh would lower when parked then lift immediately after starting again.
If a height sensor was faulty or improperly calibrated it would drop overnight as the car tried to self level itself. 2012 TDV8 Vogue (L322) |
Thank you |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
No matter what diagnostic system you used, to me I would think that all height sensors should give similar values when the car is at at a steady level height.
From the IID manual...
@Haylands Thanks for correcting me, I did not know about that aspect of the height sensors, it just seems to defy logic |
Yep, it confused the hell out of me first time I did a calibration, mine were all over the place....!!! Pete
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Had a go at setting my heights, a few years ago, just before a service. My indy gave me a right telling off.😳 Previous cars:
Why? - did he think you were depriving him of income by DIY? 2012 TDV8 Vogue (L322) |
