Home > Maintenance & Mods (L405) > L405 Supercharged 2013 - 1st Major problem in 10 years
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Afternoon,
Post #669420 19th Jul 2023 3:40pm
Can't guess what that would be but good luck, hope it's a cheap fix.... Thumbs Up Pete
Post #669423 19th Jul 2023 3:44pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
May be worth checking / cleaning the earth terminals located behind the front wheel arch liners - a few earth cables terminate here and due to the location, can suffer corrosion / bad earthing.
The liners are easy to remove, providing easy access to inspect 👍 Jonathan
2007 Defender 90 XS Hardtop
Post #669428 19th Jul 2023 4:27pm
DrF
By the way I have to say the garage have been brilliant.
Post #669430 19th Jul 2023 4:28pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
The alternator is driven by an external belt. The timing chains are internal. While technically connected as part of the entire system, you cannot put an alternator out of timing alignment as it is not timed to the engine.
My alternator failed last year due to oil leaking into it from a valve cover leak. I was able to charge the main battery and drive it for about 15km before experiencing similar symptoms as you. It was a PHEV for a few weeks.
Perhaps the new alternator failed due to a similar issue as my 2013? Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #669567 21st Jul 2023 11:28pm
DrF
Thanks Bora
Post #669596 22nd Jul 2023 4:30pm
fisha
It could be a simple case of an incorrectly fitted connector. I imagine that to replace the alt you need to unplug and remove a few things first. If some of those connectors are not fully home you could get rough running. Things like camshaft sensors, manifold pressures etc etc all affect the timing and engine mgmt decisions, and even just one missing can be enough for it to throw a wobbly.
That being said engine diagnostics should pretty quickly show up issues as pointers to look for. V8 or else ...
Post #669846 26th Jul 2023 12:24pm
DrF
Thanks Fisha,
They have said its throw cam shaft errors, I assume that is cam sensors maybe, now wont turn over, its sitting waiting its turn in the garage.
DrF
Post #669874 26th Jul 2023 5:56pm
