Home > Maintenance & Mods (L322) > 2010-2012 heated steering wheel retrofit
AG129
United Arab Emirates
Hello
I don’t own a Range Rover yet, I’m looking at various options here locally. I managed to find a couple of nice Autobiography Supercharged variants. One of them though doesn’t have a heated steering wheel, despite having both front and rear heated seats and rear reclining seats.
Is it easy to retrofit a heated steering wheel from another 2010-2012 Range Rover? I know I would need a full steering wheel and the heating module behind the airbag I believe. Would I need anything else such as the clock spring for the steering wheel, would I need a different wiring harness or does it come pre-wired from factory.
Honestly I was hoping to get a TDV8 4.4 but those aren’t available locally here at all. So I’m targeting Supercharged variants with autobiography being an added bonus. I thought those would have most options listed as standard, but apparently not.
Post #669820 26th Jul 2023 5:14am
dingg1
Wtf will you ever need a heated steering wheel in dubai?? 🔥😎
Post #669822 26th Jul 2023 9:18am
AG129
🤣 well that’s good point. I just like the idea of having that option regardless, and was wondering if it could be done.
Post #669825 26th Jul 2023 10:03am
Merchy
dingg1 does have a point here....
Having been to Dubai numerous times, ie flew into Dubai once and the temp was 49 degrees, then by car to Fujairah where it was 52 degrees......Heated steering wheel.... Thud Rolling with laughter
Post #669838 26th Jul 2023 12:13pm
AG129
Yes I realize how you might find this hilarious, but my question is about whether or not it is possible not if it should or shouldn’t be done based on the climate where I reside.
If you have technical know how or experience pulling this off, then please by all means share it…if not then what’s the point of your reply
Also shouldn’t all Autobiography Supercharged RR have most of these options as standard, including 360 cameras, adaptive headlights, rear seat TV in the front seat headrests etc?
Post #669840 26th Jul 2023 12:23pm
those replies are in jest so please dont take offence..
using the forum search i found this,
https://www.fullfatrr.com/forum/topic64815...ring+wheel
theres probably more threads on this...
theres also the workshop manual you can download from the wiki that might help.. ... - .- -.
Post #669842 26th Jul 2023 12:33pm
Merchy
Cheers Stan, you beat me to it.
Stan beat me to it AG129, this is what I was writing in reply, there is plenty of info in the Wiki and search functions, as you are new here, you may not know the site well yet, perfectly understandable.
Another old thread post similar to Stan's link is shown below
You could ask at your local JLR dealer, or try asking at a good independent specialist, they will be able to answer your question, then go from there.
Once you get to know the site, it will be obvious that whilst many of us can be comedians at times, we do go out of our way using our time to help others. Differ with decorum is my motto.
Post #669843 26th Jul 2023 1:05pm
AG129
Thanks a lot Stan. It seems this might be doable, I’ll research it more. Also the forum Wiki link in your sig is a big help. I was looking for something like that for the L322 prior to purchase.
Post #669844 26th Jul 2023 1:07pm
AG129
Cheers Merchy and thanks for the link as well. I’m just trying to get as much knowledge about the last iteration of the l322 2010-2012 as I can before I make a purchase.
Post #669845 26th Jul 2023 1:10pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Interesting, Webasto was installed to all L322? Even for hot countrys, like Dubai? If so, there is a lot of never used heaters.
Post #670001 28th Jul 2023 5:29pm
Archieatkins
2007 Range Rover Vogue TDV8 Java Black
not to hijack this threat but do L322 steering wheels fit all year types?
Post #670012 28th Jul 2023 7:46pm
