Home > Technical (L405) > Ride quality -16 SDV8 AB |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7840 |
Is there any way you can manually send the signal to the dampers? Force them soft? I’m guessing not very easy, but would prove something one way or the other…
22nd Jul 2023 6:58pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1209 |
It is possible to buy all kinds of signal generators that are not expensive, however, I do not have any knowledge as to where you could 'tap in' to the circuits to 'inject' a pre-set signal to feed all four dampers. |
22nd Jul 2023 7:08pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 687 |
I'd need some sort of generator to create the 1.5 amp 526hz(?) PWM signal.
23rd Jul 2023 8:16am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2537 |
My L322 only shows 35-40% duty cycle when travelling at about 20 kph over very rough hard ground.
23rd Jul 2023 8:55am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
There was a post elsewhere regarding these harsh riding cars, stating they disconnected the drop links and did a test drive to find the ride improved.
23rd Jul 2023 11:19am |
That's really helpful Graeme thank you.
23rd Jul 2023 12:08pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1400 |
You could probably disable the roll bar by disconnecting the connector on the valve block that controls the hydraulics. I think when disconnected there will be no pressure applied and effectively disconnected.
24th Jul 2023 6:35pm |
Hi Fisha,
24th Jul 2023 9:49pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
I've got several things crossed for you.... Pete
25th Jul 2023 8:01am |
Flashed it first thing this morning Pete before work, not made a difference. |
25th Jul 2023 8:27am |
That's a shame.....
25th Jul 2023 8:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
would a battery disconnection at this point help...maybe it will re-boot the system after the flash..[like on a pc] ... - .- -.
25th Jul 2023 8:52am |
Yes Pete all been checked,
25th Jul 2023 9:06am |
Maybe they all caught the bug off you....
25th Jul 2023 10:39am |
