Home > Maintenance & Mods (L322) > RR ‘02 air suspension is going down after replacing bags
Gsxr1250dave
Menno RR vogue 02 wrote:
Gsxr1250dave wrote:
What brand did you fit ?
I fitted aerosus ones:
https://aerosus.nl/land-rover/range-rover/...zijde.html
That brand is well known as poor quality cxxp
Post #669517 21st Jul 2023 9:00am
Gsxr1250dave
Post #669519 21st Jul 2023 9:05am
Menno RR vogue 02
Netherlands 2002 Range Rover Vogue 4.4 V8 Epsom Green
So I removed the relais and it still dropped. But is still think it’s not a leak because of what happens when I lock the car. If I unlock the car after it’s dropped down and without doing anything I lock it again it lifts very fast. It lifts within a few seconds and it’s back on original height.
Or is that normal?
I will check for leaks later this week just to be sure.
Thanks again
Post #669696 24th Jul 2023 11:20am
You have a leak, that behaviour is the system levelling, it's what you prevented from happening by removing the relays.... Pete
Post #669697 24th Jul 2023 11:30am
Menno RR vogue 02
Brilliant thank you! When the weather clears I wil do a proper check for leaks.
Post #669699 24th Jul 2023 11:40am
