Home > Technical (L322) > EGR Temp Sensor
PaulCee
EGR Temp Sensor
Well I thought I would try this after reading the great instructions from GGDR.
I will give full write up on it, and will add it to the post started by GGDR, but I have a question.
All done and sensor back in the engine. I just wanted anyones opinion who has also done this, if it looks seated correctly. It would not wind in any more, but there seems a bit of a gap between nut and engine block.
But after looking at the old nut, the thread does not go all the way to the top, so maybe this is the reason for the gap
Any help is appreciated
Thank you.
Post #669348 18th Jul 2023 8:15pm
garyRR
Yes, when tightened, it sits slightly proud. I took a photo of before I did the work and can confirm.
I wrote a guide here: https://www.fullfatrr.com/forum/topic67357.html 2015 Range Rover Autobiography 4.4 SDV8
Post #669354 18th Jul 2023 9:23pm
PaulCee
Thank you Gary for the help.
It was such a task just don’t want to mess it up.
Thanks
Post #669362 18th Jul 2023 10:49pm
