![]() | Home > Technical (L322) > Obsolete from LR - L322 ABS/ Wheel Speed Sensor |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
Island 4x4 are showing a replacement by Delphi whose parts I have used and been happy with. Others on here have also recommended Delphi. If that is of any use to you.
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 114 ![]() ![]() ![]() |
Thanks Weegie, I know Delphi very well - used to work for them! I was working for Delphi on the wiring system from the very early development with BMW.
Kevin, I am in the process of having my aircon re-done on my 2008 Tdv8. One of the parts is a hose connecting the compressor to the condenser. None available in the UK, including Land Rover. I am waiting on delivery from Belgium from a company I had dealt with when living in France.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
The Bosch ABS sensor is freely available at £50ish, Delphi and TRW (who made a number of the braking components) are around £30-35.
Hello Gary,
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 37 ![]() ![]() |
As a side note - it might be worth checking your ABS reluctor ring on that drive shaft too while you're there.
Thanks for that tip. I have seen videos of reluctor rings corroding and coming loose, so I will check that.
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 373 ![]() ![]() ![]() |
Not wanting to divert Epsom Green's thread too far off-topic, but for hydraulic hoses, I always use a local place that makes them for plant, forklifts, etc. Just take an old one and they'll make one up. I remember a few years ago I had an old Silver Shadow that needed a hose, RR wanted hundreds for one. Local hydraulic hose place: £26. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green Spiffing wheel centre caps, L322 sill repair panels, etc |
Yes I've done a few on various projects, very easy to change and cost effective compared to a new driveshaft. A new ring is normally less than £10 whereas a shaft is normally hundreds. It may be fine of course, it'll be interesting to see if the sensor has just failed on it's own or not. All the best. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
Very easy when you have the driveshaft out....
Yes, I am not looking forward to tackling this job!
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
The biggest pain doing this job is slackening / removing old rusty fastenings, apart from that the job is not too bad, a powerful impact wrench makes the job a lot easier, plus daily application of WD40 or similar every day for a week prior to dis-assembly. But...I am a marine engineer so its second nature to me...as for re-fitting the drive shaft it was only a little bit of a faff to match up the splines to fit the drive shaft and to engage the shaft into the knuckle / hub. To get the drive shaft into the 'fully inserted' position into the diff, once the splines were engaged I gave the shaft a small tap with a lump hammer to push the shaft fully home and get the spring clip to open into place as shown in the photo below. Support the drive shaft ( I used zip ties )so it is lined up and use wood to protect the end of the splines when tapping into place.
For the above post, I do not know how I minimised the photo, hope I get it right this time |
Thanks Merchy, great information.
