Changing the battery won't effect that piece, did you use new branded batteries, lots have found the remotes only work with new, fresh, top spec batteries....
If you want to get that open then it looks like it has a screw in each corner... maybe not though, if it hasn't then a lot of these things are sonic welded together so you would have to cut it open.... Pete
