Home > Technical (L322) > Burning Smell from Engine Wheel Arches
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi,
L322 Westmister 68,000 miles 44 TDv8
Car due for a Service A. I have had to have open heart surgery so not had time to take the car in.
It was booked with am Independent just before I was rushed in.
Wife been running me to appointments and there is a light burning smell from the wheel arch, mainly the nearside on my RHD car.
Any suggestions welcome please?
TM
Post #668827 10th Jul 2023 6:29pm
mjdronfield
Oil burning or electrical burning? Could be the O rings at the rear of the engine if it’s oily smell. Can’t help if it’s electrical.
Hope the road to recovery is smooth for you.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #668831 10th Jul 2023 6:47pm
TeeMyob
oily, are the o ring seals a big job ?
Post #668832 10th Jul 2023 6:52pm
TeeMyob
https://www.fullfatrr.com/forum/post576267.html
? is it these ?
Post #668833 10th Jul 2023 6:54pm
mjdronfield
Yeah. I think there is a how to somewhere. Not done them myself but if you take the air inlet box off under the windscreen with the bonnet open I believe you can get to them.
Failing that, it’s the oil cooler leaking oil into the V of the engine…. Check coolant has no oil in it, as the oil cooler uses water to cool it and when the seal goes or it warps, cross contamination occurs.
That’s another known issue.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #668834 10th Jul 2023 7:06pm
mjdronfield
Don’t forget that the fuel burning heater is under the near side wheel arch too, but prob not that as it’s probably too warm for it to come on.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #668835 10th Jul 2023 7:09pm
CS
Brake caliper sticking? Only Range Rovers since 1988
Post #668838 10th Jul 2023 7:25pm
garyRR
My initial thoughts are:
1. The FBH may have developed a fault and is running when it shouldn't be - when you can smell the oil, listen by the wheel arch to see if you can hear it running. If so, you can remove the fuse or bridge the fuel pump to it
2. The Indepenent (whatever work they did) left a little oil in the engine bay, and it's only just burning off, as the vehicle has been laid up
3. O-rings, o-rings, o-rings (and gaskets). If it's been laid up, oil has a habit of making its way to the other side of a seal
- oil feed hoses on the top of the back of the engine may be dripping oil down the back of the block (it then lands on the bell housing)
- oil cooler o-rings
- it may be trying to do a DPF regen
‐ rocker cover gaskets may be seeping a little
I think my first step would be to take it for a 20 mile drive on a motorway.
If you're able to get under the car, I'd look up to the rocker covers with a torch, and also at the bell housing. Otherwise I'd let the garage put it on a ramp and give it a quick inspection whilst you wait as a subsequent step. Places like Kwikfit will do this for you too. 2015 Range Rover Autobiography 4.4 SDV8
Post #668840 10th Jul 2023 7:55pm
TeeMyob
thank you all for your responses
Post #668886 11th Jul 2023 12:29pm
JayGee
The smell tests;
'Acrid' - Brakes (very distinctive)
'Sweet' - FBH (diesel burning)
'Rich' - Engine Oil
'hot oven' - DPF regeneration 2012 TDV8 Vogue (L322)
Post #668889 11th Jul 2023 1:00pm
TeeMyob
Yes, the local independent has told me its the oil cooler and its £1000 to fix
thank you
Post #677550 8th Nov 2023 6:50pm
mjdronfield
Some folk have got away with just replacing the gasket in the cooler, but mine had warped so needed a new cooler. There is plenty of flushes to do on the coolant if it’s got oil in.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #677576 8th Nov 2023 10:23pm
TeeMyob
Thanks.
No oil in the coolant yet !
Post #677625 9th Nov 2023 7:10pm
