Home > Maintenance & Mods (L322) > Worked on L322, now it won't start! [2010 Vogue SE] |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Did you leave a door open and wore the battery down... maybe worth charging overnight.... Pete
8th Jul 2023 7:39pm |
joel-h Member Since: 23 Sep 2018 Location: Kent Posts: 35 |
Good shout, this L322 is new to me (bought it off another forum member and loving it so far!) so I'm not sure how good/bad the battery is. The car was unlocked with key in for a few hours today during/after the work but not with doors open.
8th Jul 2023 7:42pm |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
The battery is low. It's as simple as that. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
8th Jul 2023 7:52pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Could also be the brake switch - be sure to press very hard on the brake pedal to start it. This happened to me after I changed the rear disks and pads recently. Brake pedal went from very soft to very hard and I couldn't start the car. Pressed the brake pedal much more firmly (standing on it) and hey presto! The older I get, the more I realise that people confuse wrinkles for wisdom |
8th Jul 2023 8:25pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
I’ve got a leak on my servo and have to press the brake very hard after leaving it a few days for the starter to work but agree with others this may simply be a drained battery. 2012 TDV8 Vogue (L322) |
8th Jul 2023 10:06pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Sometimes after brake work you have to press *REALLY* hard on the pedal to get it to start.
9th Jul 2023 12:28am |
And that was it!
9th Jul 2023 5:34pm |
9th Jul 2023 7:52pm |
You're welcome! The older I get, the more I realise that people confuse wrinkles for wisdom |
10th Jul 2023 7:48am |
