Home > Maintenance & Mods (L322) > AC clutch question help.
garyRR
The workshop manual should be in the Wiki: https://drive.google.com/file/d/0Byv5LFgQZ...miKhxIqatA
If attempting yourself, you'll need to get a garage to vacuum the gas from your system (this should be free), then the work can be done, then return to the garage to have it leak tested and then recharged with refrigerant.
 2015 Range Rover Autobiography 4.4 SDV8
Post #668592 7th Jul 2023 1:51pm
Weegie
If it hasn’t already been done, it’s also an opportunity to change the belt and tensioner. John
GAP iiD BT
Post #668593 7th Jul 2023 1:57pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Amazing-thank you!
Post #668597 7th Jul 2023 2:18pm
philip1972
Having been out today again in 29 degree heat and run the IID for the trip, it seems the AC comes and goes.
Evap temp goes from 9 ish to ambient, then back down as I drive along. Pressure was pretty stable at 11-12 bar.
Post #668605 7th Jul 2023 4:36pm
garyRR
Sounds like the valve Thumbs Up 2015 Range Rover Autobiography 4.4 SDV8
Post #668610 7th Jul 2023 5:06pm
