Home > Maintenance & Mods (L322) > Violent Jolt/Shudder
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Not sure of the best way to describe this but it's happened a few times now that whilst I am towing a heavy catering unit and the car is under load up an incline I get what I can only describe as a violent jolt/judder/bang that's quite unnerving sounds like it's coming from underneath but no lights on the dash or anything obvious,I'm not at all mechanically minded but wonder if it's transmission related ?
My 2011 Range Rover is a 4.4 TDV8 and on 94,000 miles
Post #664700 22nd May 2023 2:50pm
StevieF2
Transmission Shudder
Hi Devon chilliman
This appears to be a common problem with these cars as there are a few posts on it.Sounds like the rear prop shaft centre bearing is worn or the Torque convertor.
Lots of posts on here stating that Dr Tranny shudder additive will solve the problem if its oil related but I have the same problem on my 2009 RR. Vogue and will try replacing the bearing and adding the additive
The centre bearing is about 21 quid from LR spares in Speke and Dr Tranny is about 12 quid a tube
I'll report back once these fixes are done
Good luck with yours
Regards
Steve
Post #664844 24th May 2023 12:10am
devonchilliman
Morning Steve
Ahh that's very interesting to hear,I do have an extended LR warranty on the vehicle so will see what they say Thumbs Up
Post #664860 24th May 2023 7:22am
DrRob
Centre bearing on rear prop is not a straightforward swap on later L322 as it was earlier ones.
Common wisdom is to change the entire prop on later ones (I've done a fair amount of research on this)
Advanced Factors do a GKN one and don't forget we have a forum discount code. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #664869 24th May 2023 8:49am
StevieF2
Transmission Shudder between 30-50mph
Hi again
As I said I'd follow up
I have just had the rear prop shaft centre bearing changed out on my 2009 RR vogue plus two tubes of Dr Tranny shudder fix for good measure and it's all good now, and drives like a new car.
The Mechanic said the centre bearing was shot and that was the cause of it as I expected after reading the forum as I said it seems to be a common problem.
I have had the transmission filter, sump pan and transmission oil changed as part of the sale in early April.
I'd suggest you get your mechanic to look at the bearing to check for condition and play as a starting point and if you haven't had the gearbox serviced then I'd get that done too (around 500 quid)
I'd also recommend Dr Tranny treatment as well.
Good luck
regards
Steve
Post #665406 29th May 2023 4:39pm
devonchilliman
Cheers for that StevieF2 Thumbs Up
I rang the stealers and they can't get me in until July 4th Censored Rolling Eyes
Post #665420 29th May 2023 5:55pm
StevieF2
Hi
Its not a specialist job to be honest and any good and competent mechanic and garage can sort it for but if the car is under warranty then the dealer is the way to go.
Good luck and I'm sure it will be the propshaft centre bearing that's at fault like mine, if not it could be the Torque convertor but I would highly recommend that you have a gearbox oil service as mine hadn't been done from new in 2009 and the oil and filter were in bad condition.
If its not the centre bearing and the gearbox oil and filter is in good condition then I would put in two tubes of Dr Tranny shudder fix as a lot of people swear by that in the blogs I have read
Steve
Post #665461 30th May 2023 9:43am
devonchilliman
****UPDATE***
Finally the stealers have got round to looking at my motor and as StevieF2 said its the propshaft centre bearing that's worn Thumbs Up
Hoping now that it's covered by my Extended LR Warranty
Post #668473 6th Jul 2023 7:31am
DrRob
If not, fit a GKN (OEM) one from Advanced Factors. I've just had this done.
Don't forget discount code Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #668483 6th Jul 2023 8:58am
devonchilliman
Phew!!
Just been confirmed that a new propshaft is covered under my LR warranty Bow down
I also mentioned that it seems to hang onto gears more than it used to and that a gearbox oil change would sort this but a cost of over 1K Shocked but as a goodwill gesture ( after shocking lack of service down to Vertu Motors) they can do it for £850 but that still seems a crazy amount of money Rolling Eyes
Post #668574 7th Jul 2023 10:39am
DrRob
I paid half that for a Bodsy Megaflush. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #668586 7th Jul 2023 12:27pm
devonchilliman
Funny you should say that as I've messaged Bodsy earlier Thumbs Up
Post #668588 7th Jul 2023 12:40pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Bodsy done a special offer day a while ago
Mega flush, front diff, transfer box, rear diff
£455
Do some research first mate is all I'd say
Post #668602 7th Jul 2023 4:22pm
