Anyone Actually Managed To Drain Coolant On L322 4.4 TDV8??? | |
Hi everyone.
I have carried out the common oil cooler fix on my 2011 4.4 TDV8, but still have some oil in my coolant, so I'd like to do a full coolant flush and refill.
I've downloaded the procedure in question from the workshop manual in the Wiki. The problem is, access to the area to disconnect the bottom coolant hoses is extremely difficult. It doesn't help that the hose clips on my car are oriented in the most awkward way, and there seems to be almost no room to get tools in to remove them. I've tried a selection of different pliers and grips, but I'm almost at the stage of admitting defeat and booking it in to a garage.
Has anyone actually done this themselves? Any advice or recommendations on how to actually get a tool onto that clip?
Also, I can easily locate the hoses on the transmission fluid cooler and the secondary radiator in the OSF wheelarch, but I'm struggling to even find the two smaller hoses mentioned later in the procedure.
![](https://www.fullfatrr.com/gallery/albums/userpics/26172/normal_IMG_8705.jpeg) | Click image to enlarge |
![](https://www.fullfatrr.com/gallery/albums/userpics/26172/normal_IMG_8706.jpeg) | Click image to enlarge |
![](https://www.fullfatrr.com/gallery/albums/userpics/26172/normal_IMG_8703.jpeg) | Click image to enlarge |
![](https://www.fullfatrr.com/gallery/albums/userpics/26172/normal_IMG_8700.jpeg) | Click image to enlarge |
![](https://www.fullfatrr.com/gallery/albums/userpics/26172/normal_IMG_8695.jpeg) | Click image to enlarge |
