![]() | Home > Maintenance & Mods (L322) > DPF - DPF Doctor |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Given DPF doctor sells DPF cleaning, that's all they'd probably recommend. The DPF filling is a symptom on these cars, so I'd be highly doubtful a clean would ever cure the problem and it would just return, meaning wasted money.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3204 ![]() ![]() |
What Gary said. You have a leak in your pipes or maybe a prob with your sensors or even your thermostat/housing (mine was damaged during a repair and made the engine run too cold to regen fully).
glenney Member Since: 04 Jan 2021 Location: East Sussex Posts: 21 ![]() ![]() |
Thanks for the reply. No doubt you are right. Its a bit odd as the Indy that I use said no air leaks and sensors were all ok when I was there so Im guessing what the cause could be.
Have you had a HIGH pressure smoke test done? bear in mind my inlet manifold crack was very small and only just perceivable with a smoke test but had a huge effect on the DPF. |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Agree with other comments, there is clearly something amiss here. Being gluttons for punishment we have two L322 TdV8 4.4's, one does mainly short journeys (less than ten miles generally) and the other does mainly long motorway journeys. We've owned both for over three years and neither has ever had even a DPF warning light, let alone an actual problem. Always change oil regularly every 7500 miles max and always use correct grade premium product (usually Shell Helix) and never use supermarket fuel (generally it's Shell from the local fuel station, but always premium), I have no idea if this is a factor but compared to what others seem to be getting DPF trouble wise I reckon this is actually the cheaper option. Drives:
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
Glenney, yes I have used DPF Doctor through one of their franchise sites in Newbury at Millers Garage. I would recommend. They do know what they are talking about and, as others say, your DPF is the symptom and not the cause. Their USP is not simply cleaning DPFs - it is an holistic approach to the whole system and they are well aware of the impact of intake-side leaks etc on soot build up. When and only when they have identified why your DPF is not operating as intended, they will chat to you about options going forward. As long as the DPF is not damaged, they will be able to clean it which will give you an ‘almost new’ DPF. However, it is very important to diagnose the cause of the problem. Good luck! 👍 Andy
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
I second that approach sir... Needs diagnosing properly... |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 121 ![]() ![]() ![]() |
Have a read here:
DPF's are designed to last way longer than that before ash buildup becomes a problem. The extra fuel used during regeneration is insignificant. 2012 TDV8 Vogue (L322) |
