Home > Maintenance & Mods (L322) > Rear brake line replacement - Any contacts?
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Due to corrosion on rear brake lines my car has failed its MOT.
I am having issues finding someone that can do custom replacement of the rear brake lines in copper as the main garages I have spoken to all want to install the pre-shaped OEM pipes that require the whole rear end of the car to be dropped.
Does anyone know any garage or specialist individual that is able to do the job? I am on the Essex/London border, but flexible to travel within reason as the car failed its MOT and I really want to get it back on the road. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #667971 30th Jun 2023 2:16pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I presume you mean copper - nickel pipe rather than pure copper ?
Pure copper used to be common, but is not very durable because its too soft & easy to damage & actually goes brittle with age.
Most people use copper nickel - which is easy enough to bend or add flared ends to, but stronger.
PS Sometimes called Kunifer.
I'm surprised you can't find anyone so far.
Good luck ! Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #667974 30th Jun 2023 2:37pm
AnotherMutley
What about Glenrands?
Post #667975 30th Jun 2023 2:40pm
Flashman
Yep, copper-nickel or what variant brake lines are made of. Not interested in OEM that will only corrode again.
I have tried one contact a garage gave me that used to visit customers at home and install on their driveway but he has gone silent.
I am going through local garages at the moment and so far they will only install the pre-shaped off the shelf lines. Tom
Current Drive
Previous Drives
Post #667976 30th Jun 2023 2:43pm
dhallworth
I did this job recently on a friends TDV8. It's not as bad a job as you'd think.
The connectors for the pipes are just behind the front wheel arch and they're easy enough to run. I dropped the fuel tank guard on the NS to give enough access without removing the whole thing.
Hopefully you'll find somebody soon.
Post #667977 30th Jun 2023 3:03pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Out of curiosity; does anyone know of a reason why braided brake lines can’t be used ?
My motorcycle is kitted out with braided Venhill lines : https://www.venhill.co.uk/hydraulic-lines-...ngths.html
P.S. I was also wondering about branded lines to replace the steering pump lines. TDV8 4.4 2012
Post #667984 30th Jun 2023 4:24pm
Pawl
Flexi hose (braided etc) expand under pressure.
Due to the lengths required to replace the existing metal pipes, the effect on the brake pedal at high braking forces would be noticable.
For just the necessary existing flexing sections, the effect is tolerated as relatively insignificant. Paul,
Post #668014 30th Jun 2023 10:45pm
Ennoch
I always thought that too, until we had to re-line one of the rally cars in a bit of an emergency and ended up using full braided line throughout. You couldn't tell the difference between hard line and the braided stuff, both were rock solid. Way more solid than any normal car's system feels with a vacuum booster etc. I still wouldn't necessarily choose it as my first option but it really isn't poor performing.
Post #668103 1st Jul 2023 7:18pm
Pawl
I think braided hose has probably improved over the years, but it's still a fundamental that anything that can flex will flex / expand under high pressure.
I think the Rally Car probably had the advantage that it had a large diameter mastercylinder & reduced servo assistance for best feel & shorter pedal travel compared to an RR & being significantly lighter would not have needed the higher pressures a fully laden RR needs for maximum braking.
That said, I'm sure the increase in pedal travel at high pressures with the rear end of the RR converted to braided would be no big issue.
It would be considerably more expensive than copper nickel pipe though Very Happy
Paul Paul,
Post #668120 1st Jul 2023 10:39pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Interesting, I fitted similar hoses to our MG and I noticed a difference as the pedal felt a little firmer with more feedback over the OE flexible hoses.
I had never before considered them to replace the steel/copper lines.
As to cost yes more expensive but not silly if i remember right it was around £30 for 2.5m. They would be much easier to fit, I think, with maybe larger bend radiuses but would they require more fixings to the body work to pass an MOT?
So an interesting option, more thought/research required.
I also think that fitting these to the rear of our cars would have no effect on braking performance as the rears only contribute a small amount to the overall braking power needed, I believe around 20% ish.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #668123 2nd Jul 2023 1:03am
JayGee
Teflon lined stainless steel braided hoses are not like OE rubber and textile flexible hoses. An issue for the MOT would be if they are legal for road use as brake fluid is highly flammable. 2012 TDV8 Vogue (L322)
Post #668130 2nd Jul 2023 11:22am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Freeway on the Isle of Sheppy is not too far from you and don`t need to take the subframe off. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #668134 2nd Jul 2023 12:57pm
Ennoch
Paul
Oh for sure. I probably wouldn't willingly replace the lines on a full road car with it (we were routing the lines through the car) as it would be bloody expensive. For us we had a reel and a bunch of fittings sitting there at 11pm so as they say, it was the right solution at the right time for the right people!
Where I was coming from with the thoughts here was in relation to the back end where on most cars (I've never had to replace lines on either of my previous L322's) it's an utter PITA to route hard line through the subframe/tank etc, and that replacing the hard line with braided flex up and over that section may save a lot of arse. Even if it was more expensive, for the time and effort/swearing saved it may be a trade off worth considering. On the Impreza I've got a full set of OEM rear lines and connector blocks waiting to go on while I've got the tank and subframe dropped as a preventative measure. If they blew without me doing the tank etc already I'd be inclined to either re-route and/or use the flexi.
It's an interesting point @JayGee on the legality of them. I've never seen any issue with braided lines going through an MOT (pretty much all my cars have had them fitted over the last 20 years) and there's nothing from what I could see in the MOT regulations that it could fail under. With regard the fire resistance, they're going to be better than rubber line, and braided line is preferable in race cars to rubber due to its fireproofness. Obviously you're comparing braided to kunifer etc but full fuel systems are made with this stuff so I don't really think it's an issue. Not having a jab at you though, and I'm happy to be proven wrong if I've missed something!
Post #668157 2nd Jul 2023 7:06pm
JayGee
There is no problem replacing the existing flexi lines with braided as it's a like for like situation but replacing the hard lines with braided / flexi lines is another matter. 2012 TDV8 Vogue (L322)
Post #668165 2nd Jul 2023 9:07pm
Gremlin500
Laughing
Too much uninformed conjecture here. Ennoch is correct, braided of the correct specification will not expand like a clowns balloon sculptures, lol!
In my professional experience with huge industrial brakes we often run 3m runs of flexy at up to 175bar, waay more than car hydraulic pressures.
Note: “correct specification” Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #668167 2nd Jul 2023 10:02pm
