Home > Maintenance & Mods (L322) > Meyle - L322 Front Suspension Arm Kit - Thoughts? |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 |
I did sign up and have a look but the only manufacturers I recognised was Quinton Hazell & Delphi for the Arms which were £30 more per arm. Other than them it was either Borg & Beck (no thanks), Apec, Firstline, Napa or NK... It seems a bit of a lottery at the moment as to whats available, with which supplier and how much. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
26th Jun 2023 11:37am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I put Delphi track rod ends on mine in March so maybe it's these that have gone south as it does feel steering related. I need someone to turn the wheel when I'm under it to hear where the noise is coming from. 2012 TDV8 Vogue (L322) |
26th Jun 2023 11:43am |
Parts arrived on Monday from Germany.
7th Jul 2023 4:42pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
When changing the lower arms remember that the car has to be back on the ground before the bolts are fully torqued up to the recommended setting. (best not to ask how I found that out ) Personally I would always use new bolts, genuine bolts are not expensive. Advice is in the 'Wiki' section somewhere. |
7th Jul 2023 6:42pm |
Hi Merchy - Yes, good shout out - always tighten on the floor / jacked up. I've done a few of these now and took advice on here beforehand
10th Jul 2023 9:58am |
