Home > Technical (L322) > 5.0 supercharged smoking
Page 2 of 4 <1234>
chdavis
2012 Range Rover Autobiography 5.0 SC V8 Galway Green
White/grey smoke that smells like gasoline is probably just a leaky injector or PCV valves. Especially if it does it mostly only on the first start of the day or similar 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI
Post #666620 15th Jun 2023 12:11am
alh
United Kingdom 2005 Range Rover Vogue Td6 Adriatic Blue
hi could you send me vidieo please
William97841 wrote:
Well been there today and engine is knocking and bloody hell it’s smoking thick white like a cloud behind it from it. Something badly wrong with it. But just thought I would let you know also took a video of the engine if anyone wants to see it.
Post #666782 16th Jun 2023 6:34pm
alh
could you send me video please my email is alh3010@yahoo.co.uk
thanks in advance
Post #666783 16th Jun 2023 6:35pm
alh
I have bought the supercharged smoker
I will keep you updated about the smoke. ordered 2 pcv repair kits. will be putting it into gararge. It is immaculate inside and out. someone has also been at the main ECU is has seleant around it. Ordered a use ecu too. the chains were done at 112K FEB 2019 its only done 3K since then. Got all the docs for its maintenance. Watch this space
Post #667134 20th Jun 2023 7:09pm
alh
Post #667135 20th Jun 2023 7:09pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Good luck Thumbs Up
Post #667141 20th Jun 2023 7:44pm
chdavis
let us know! 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #667142 20th Jun 2023 7:47pm
Good luck, hope it's an easy fix and the gamble pays off... Thumbs Up Pete
Post #667154 20th Jun 2023 9:13pm
dhallworth
That’s 2 x 5.0 SC L322’s heading to Scotland this week Very Happy
Hopefully yours is a straight forward fix and you’re enjoying it soon!
Post #667162 20th Jun 2023 11:16pm
alh
thanks hoping it was the PCV valvels changed them still smok
Post #667387 23rd Jun 2023 4:59pm
alh
changed the PCVs but still smoking. oil geting in from somewhere. Its going to gargage so they will sort it. I think it could be the supercharger. Watch this space
Post #667388 23rd Jun 2023 5:01pm
dhallworth
The supercharger has its own oil supply which is separate from the engine. I’d be really surprised if it was they causing it to smoke. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #667392 23rd Jun 2023 5:41pm
Injector problems are commonish with them, some good diagnostics and live value monitoring should get to the bottom of it... Pete
Post #667395 23rd Jun 2023 7:00pm
dhallworth
How did you get on with the smoking issue on your 5.0? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #670770 8th Aug 2023 11:44pm
alh
Hi Guys,
The engine has no compression In pne of the cylinders.
I have a reacement 50k engine to fit. Will replace timing chain belts tensioner and pulleys including fitting smaller one on supercharger.
Do you think.I should put a new water pump and oil pump before fitting complete 50k engine?
Anthing else I should replace?
Hopefully we can fix engine when we take it out and sell it on thanks in advance.
Post #671041 12th Aug 2023 5:31pm
Page 2 of 4 <1234>
