![]() | Home > Technical (L322) > 5.0 supercharged smoking |
alh Member Since: 19 Oct 2017 Location: Fife Posts: 23 ![]() ![]() ![]() |
could you send me video please my email is alh3010@yahoo.co.uk
I will keep you updated about the smoke. ordered 2 pcv repair kits. will be putting it into gararge. It is immaculate inside and out. someone has also been at the main ECU is has seleant around it. Ordered a use ecu too. the chains were done at 112K FEB 2019 its only done 3K since then. Got all the docs for its maintenance. Watch this space |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Good luck |
chdavis Member Since: 29 Nov 2021 Location: Washington DC Posts: 46 ![]() ![]() |
let us know! 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
Good luck, hope it's an easy fix and the gamble pays off... |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3210 ![]() ![]() ![]() |
That’s 2 x 5.0 SC L322’s heading to Scotland this week |
changed the PCVs but still smoking. oil geting in from somewhere. Its going to gargage so they will sort it. I think it could be the supercharger. Watch this space |
The supercharger has its own oil supply which is separate from the engine. I’d be really surprised if it was they causing it to smoke. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Injector problems are commonish with them, some good diagnostics and live value monitoring should get to the bottom of it... Pete
How did you get on with the smoking issue on your 5.0? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Hi Guys,
