Home > Technical (L322) > Steering Rake Memory fault |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
I've got this intermittent issue with the steering column adjustment.
1st Jun 2011 6:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
a battery dis-connect usually remedies a lot of electrical problems on the range.. |
1st Jun 2011 6:36pm |
Just disconnect the negative, for how long? (May fix my TPMS too!) Discovery 4 HSE
1st Jun 2011 8:02pm |
12 hours seems to be a ballpark figure adam .... |
2nd Jun 2011 8:47am |
Is that a joke? I can't not have the car available for 12hrs!
2nd Jun 2011 10:17am |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
Over nite? OK you will have to re-connect am, but you could pretend you have a 11my with a flat battery |
2nd Jun 2011 10:21am |
+1 for over night... |
2nd Jun 2011 10:36am |
I disconnected the negative terminal that's attaches to the body by the battery, as this looked like the easiest method.
2nd Jun 2011 11:56am |
...thats the easiest way... |
2nd Jun 2011 1:12pm |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 |
Mine doesnt even move at all!!!! No memory feature. I woud assume this is a standard feature? Also seats have memory but dont "settle" in the default position when ignition is turned off. Is this right??
2nd Jun 2011 2:24pm |
FWIW I have found the 12 hours thing to be a myth. The main issue is to ensure all modules have no residual charge left in capacitors etc. Best way to achieve this is to disconnect the battery earth lead and then short it to the positive lead for 30 seconds. I actually do this through a standard 21w indicator bulb as it's a little less brutal.
2nd Jun 2011 3:31pm |
Maybe you had best explain EXACTLY how you did that Discovery 4 HSE
2nd Jun 2011 3:33pm |
this extract from rave might help...
2nd Jun 2011 3:50pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3808 |
I read your post and mine started behaving in exactly the same way Please let me know if you get a result disconnecting the battery Geoff |
2nd Jun 2011 4:21pm |
