Home > Technical (L322) > Steering Rake Memory fault
I've got this intermittent issue with the steering column adjustment. Censored
When you switch off the ignition the column rises out of your way - this is fine. Very Happy
Then, next time you unlock the car it should lower to your previous setting or the memory, I keep finding mine won't come down. I have tried pressing my seat memory button that it is supposedly stored against and nothing happens. Mad
So, I go for manual intervention (Can't beleive as a RR owner I have to adjust something! Laughing )
On first touch of the adjuster it moves about a milimeter and stops, then on the second try it moves a bit more, then on the third try typically it starts moving fluidly and I can put it back to where it should be.
I read Dan's post about the steering adjuster tabs breaking etc but I don't think this is the same issue.
Does anyone have any ideas other than a potential software problem what this could be?
Thanks all. Discovery 4 HSE
Post #66638 1st Jun 2011 6:13pm
T24RES
Mine does this from time to time. I disconnected the battery, seems to have gone away for the past couple of weeks.
Post #66642 1st Jun 2011 6:23pm
a battery dis-connect usually remedies a lot of electrical problems on the range..
Post #66647 1st Jun 2011 6:36pm
Just disconnect the negative, for how long? (May fix my TPMS too!) Discovery 4 HSE
Post #66661 1st Jun 2011 8:02pm
12 hours seems to be a ballpark figure adam ....
Post #66697 2nd Jun 2011 8:47am
Is that a joke? I can't not have the car available for 12hrs!
I tried it for ten minutes, the TPMS light has gone out but I would guess it will come back on after my next drive. Discovery 4 HSE
Post #66711 2nd Jun 2011 10:17am
nbunney
Over nite?
OK you will have to re-connect am, but you could pretend you have a 11my with a flat battery Rolling with laughter
Post #66712 2nd Jun 2011 10:21am
+1 for over night...
Post #66714 2nd Jun 2011 10:36am
I disconnected the negative terminal that's attaches to the body by the battery, as this looked like the easiest method.
As long as you break the circuit the end result is the same yes? Discovery 4 HSE
Post #66721 2nd Jun 2011 11:56am
Thumbs Up ...thats the easiest way...
Post #66741 2nd Jun 2011 1:12pm
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Mine doesnt even move at all!!!! No memory feature. I woud assume this is a standard feature? Also seats have memory but dont "settle" in the default position when ignition is turned off. Is this right??
cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #66746 2nd Jun 2011 2:24pm
mzplcg
FWIW I have found the 12 hours thing to be a myth. The main issue is to ensure all modules have no residual charge left in capacitors etc. Best way to achieve this is to disconnect the battery earth lead and then short it to the positive lead for 30 seconds. I actually do this through a standard 21w indicator bulb as it's a little less brutal.
NOTE I SAID LEADS. DO NOT SHORT THE BATTERY TERMINALS UNLESS YOU LIKE FIRES. EXPENSIVE FIRES!!
Post #66753 2nd Jun 2011 3:31pm
Maybe you had best explain EXACTLY how you did that Shocked Discovery 4 HSE
Post #66754 2nd Jun 2011 3:33pm
this extract from rave might help...
Post #66759 2nd Jun 2011 3:50pm
supershuttle
Re: Steering Rake Memory fault
Thanks all.
I read your post and mine started behaving in exactly the same way Sheep
Please let me know if you get a result disconnecting the battery Thumbs Up Geoff
Post #66764 2nd Jun 2011 4:21pm
