Home > Technical (L322) > TDv8 Secondary air charge valve actuator vacuum hose routing |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3241 |
That’s the front diff vent pipe. 2012 TDV8 Vogue (L322) |
17th Jun 2023 6:55am |
PieRat Member Since: 17 Jun 2023 Location: chch Posts: 5 |
Thanks JayGee, I thought it must've been a breather pipe.
17th Jun 2023 8:13am |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 |
If you remove the large air intake rubber hose from the intercooler to the throttle body and then investigate down the front of the engine under the passenger side (UK) rocker cover you will find hidden a solenoid valve with several vacuum pipes attached and this is where the other end should go. I only know this because I had the two pipes which run from the vacuum pump come off when I was investigating a coolant leak a couple of weeks ago. I found the rubber tubes which they plugged into had ‘relaxed’ with age and were not gripping the plastic tubes. As a fix for now I put small cable ties around each joint to keep them in place. It was a fiddle due to the limited access but seems to be working so far. 2012 Westminster TDV8 4.4 Indus Silver
18th Jun 2023 11:45am |
thanks for that. With your directions I was able to get that line plugged in and now the second turbo works. Never expected it to be located there to be honest cheers |
18th Jun 2023 8:31pm |
That’s good news, pleased you have got it sorted. 2012 Westminster TDV8 4.4 Indus Silver
19th Jun 2023 5:46am |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 63 |
Hello everyone,
21st May 2024 2:03pm |
PAYNTS Member Since: 23 May 2024 Location: Bedofrdshire Posts: 13 |
did you manage to source the pipes for this or do you have to buy the whole pipe assembly ?? |
28th Jul 2024 9:18am |
I couldn’t find the second pipe, I think its sold as whole assembly. I just put a zip tie on the end marked with nr 2 in the picture above and replaced the first pipe 2011 Vogue SE 4.4 TDV8 |
28th Jul 2024 10:01am |
