Home > Technical (L405) > Ride quality -16 SDV8 AB |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2538 |
The brass fitting might simply not be tight enough unless you've already checked. |
16th Jun 2023 6:38am |
Following-up on the Defender's harsh ride, it appears from monitoring live values with an IIDtool that the shocks aren't receiving any power at all while moving which explains the harshness - zero demanded duty cycle, zero demanded current and zero actual current. At least the owner now has evidence of a malfunction to pursue with the dealer. |
18th Jun 2023 12:25pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 687 |
Wow that's an interesting one Graeme, did I recall you saying the Defender didn't show any fault codes?
18th Jun 2023 1:12pm |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
Watching this post with great interest as I had a 2016 L450 with same problems 😂 very harsh ride , new air bags and vds shockers front and new vds rear shockers all checked for live values , control arms link bars, tyres etc , didn’t make the slightest difference , ended up P/x ing the car as not a nice place to be although when I first got the car it was perfect , damper live values were checked while driving with iid tool and looked ok always wondered if it could have had something to do with the air crossover valves or front and rear air control valves ?? May never know now 😂 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
18th Jun 2023 2:35pm |
Glad to know I'm not alone aljo as far as harsh riding l405s go.
18th Jun 2023 4:48pm |
I’ve gone onto a 2020 se p400e. Totally different beast 👍👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
18th Jun 2023 5:35pm |
And you have no suspension complaints on that one? |
18th Jun 2023 5:37pm |
Not on this one 👍. Not yet anyway 😂😂😂😂 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
18th Jun 2023 6:02pm |
Well that's both good news that your happy with the newer car and also that I'm not imagining this but also bad news a cause for the stiff ride wasn't found on your old one.
18th Jun 2023 6:14pm |
The steering always pulled slightly to the left and geometry was dealer checked a few times and once by an independant hunter alignment specialist and all within spec, but the engine did seem to get a bit "laggy" and your certainly not imagining the ride ! the slightest bump or pothole at low to mid speeds was unbelievable for a car like this
18th Jun 2023 8:24pm |
Great feedback aljo thank you.
18th Jun 2023 8:40pm |
I did at one point after months and months of harsh ride quality have approx 2 weeks of it working fine gliding throuh potholes ect and even my partner in the passenger seat said she could feel the difference so I certainly dont think I was imagining it
18th Jun 2023 8:57pm |
No faults and assessed by 2 different LR dealers as nothing wrong. The owner of an independent LR workshop's recent comment after a brief drive was that the ride was like a D4 at super-extended height, with no suspension give. If your vehicle doesn't show a normal height only message then the leak won't be affecting the operation off the EAS system. However checking that there isn't a height sensor with values jumping about would be worthwhile as that would afect CVD operation. Better to use the IDtool to display height sensor live values from the damper section rather than rely on the 4x4 display as those values are smoothed. |
18th Jun 2023 9:07pm |
I too have had similar but limited only to 1 drive in a single day never a whole week of it being okay.
