Home > Technical (L322) > 2011 L322 Parking Sensor Volume |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
from memory you increase the volume as the parking sensors are sounding. ... - .- -.
17th Jun 2023 11:18am |
Fatbear Member Since: 23 May 2023 Location: Nene Valley Posts: 18 |
Thank you for the prompt reply, I do that but the radio volume goes up to drowning out the beeper |
17th Jun 2023 11:44am |
do you switch the radio off when doing the sendors? ... - .- -.
17th Jun 2023 11:50am |
I’ll try that 👍👍 |
17th Jun 2023 12:09pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
It has been posted before, but there's still no definitive answer to it. I've even tried to find a way of increasing the volume using the GAP tool, without success. In light of your post, I went back out to the car today in an attempt at getting the solutions presented to work (again), but no joy. Engine on, engine off, radio on, radio off, each time using the steering volume buttons or the main volume knob...... Nothing! All I have is a quiet beeping going round my head after twenty minutes of attempting to make it get louder while sat in the drive with reverse engaged. I've even removed the speaker from its position inside the rear cubby hole and left it hanging loose in the boot-space to avoid the sound dampening effect of it being behind the side panel, but it doesn't make any appreciable difference. The older I get, the more I realise that people confuse wrinkles for wisdom |
17th Jun 2023 2:51pm |
Thank you for your reply, yes I’m still trying I will let you know if I find any solution 👍👍 |
17th Jun 2023 3:00pm |
i now recall this problem not being solved..
17th Jun 2023 3:52pm |
Thank you 👍 |
17th Jun 2023 5:30pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
I always just adjust the volume when the F or R is sounding... Same on the 405 |
18th Jun 2023 1:16am |
I presume you mean that you simply turn down the stereo at the time in order to hear the parking sounders? The issue is that it's easy to forget to do this and next thing you know, you've bumped something unseen. An audible warning ought to be audible regardless of ambient noise. These (rear) sounders ain't. The older I get, the more I realise that people confuse wrinkles for wisdom |
18th Jun 2023 10:29am |
No sir, I mean, I adjust the volume of the PDC sensors when they are sounding… My car reduces the audio sound when the PDC are sounding so twiddling with the volume buttons, you never know which your adjusting? The audio or the PDC! Hence me waiting for the PDC to sound (usually by me parking against an object) then adjusting the volume to suite… 👍 |
18th Jun 2023 11:56am |
That doesn't work with mine, and probably doesn't for the OP either. The older I get, the more I realise that people confuse wrinkles for wisdom |
18th Jun 2023 7:33pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1464 |
I checked this one with GAP directly before.
19th Jun 2023 5:45am |
