Home > Technical (L405) > HVAC |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 379 |
It sounds like low pressure in the refrigerant, but not low enough that the system stops working. Mine blows icy cold within a few seconds of switching on even in this temperature.
16th Jun 2023 7:13am |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 54 |
Hi Zebedee,
16th Jun 2023 7:45am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1183 |
Get an A/C, specialist to look at it, they will have the experience and knowledge to carry out correct fault diagnostics. This is where lots of garages fail.
16th Jun 2023 8:34am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 125 |
If you have a multi-function OBD tool then you can view the real time HVAC data from compressor on/off, to system pressure, to evaporator temperature and the vent actuators position and the individual vent air temperature. That data will tell you if you have a problem and point you in the right direction to get it sorted.
16th Jun 2023 12:42pm |
Thanks very much for the replies. Found a great Indy who diagnosed a gas leak between the condenser and drier.
30th Jun 2023 6:45am |
