![]() | Home > Technical (L405) > HVAC |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 385 ![]() ![]() ![]() |
It sounds like low pressure in the refrigerant, but not low enough that the system stops working. Mine blows icy cold within a few seconds of switching on even in this temperature.
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 65 ![]() ![]() ![]() |
Hi Zebedee,
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Get an A/C, specialist to look at it, they will have the experience and knowledge to carry out correct fault diagnostics. This is where lots of garages fail.
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 142 ![]() ![]() ![]() |
If you have a multi-function OBD tool then you can view the real time HVAC data from compressor on/off, to system pressure, to evaporator temperature and the vent actuators position and the individual vent air temperature. That data will tell you if you have a problem and point you in the right direction to get it sorted.
Thanks very much for the replies. Found a great Indy who diagnosed a gas leak between the condenser and drier.
