Home > My Range Rover > Makeover for the old girl |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
It looks really good, money well spent. BMW i3 Electric Car
15th Jun 2023 9:41am |
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 |
She has been well maintained and all the usual issues have been addressed. Turbo drain mod, Oil cooler leaks, metal brake lines all replaced, Gear box serviced by Mikey of this parish at Dundee at 80k miles. Two new rear shocks, brake rotors and pads replaced several times. Stability control wiring looms on front shocks replaced. Extensive anti corrosion work: Dinitrol cavity wax injected into box sections and sub frames and underside sprayed with Lanoguard, surface rust on rear wheel arches treated, coated with Lanoguard grease and fitted with edge protectors. She should be good for a few more years. 2011 Vogue TDV8 4.4
15th Jun 2023 11:19am |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 197 |
Lovely example and same situation as me, values for newer ones still seem vastly over inflated.
15th Jun 2023 1:03pm |
