Home > General (L405) > L405 reliability |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 797 |
Would that sort of mileage ruin my experience of the 4.4 v8 diesel?
10th Jun 2023 9:35pm |
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 137 |
More concerned with the short journeys it will mainly be used for throwing up problems with a diesel engine.
11th Jun 2023 2:29pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7921 |
Ah - short journeys is different to your original post...... annual mileage is irrelevant.
11th Jun 2023 2:54pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Shortish trips at 8k mileage is similar to me. Each day, I’ll do about 4x 4 mile trips and a commute of around 20 miles each. ( plus occasional longer journeys etc ), and mine seems to moan for an oil change after about 5 months at this rate. Yes, this is a lot shorter than the typical 12 month change of other cars, but at least the car is calculating oil dilution and tells you. If you change it when it asks, then it goes back to being fine. Listening to the engine before and after the oil change, there is a difference in the sound of it post change, so it must have been needing it, so I do trust the cluster when its asking for the service.
11th Jun 2023 4:00pm |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1015 |
Had my SDV8 since Sept 2018 and in that time I’ve covered 36k miles. I don’t use the car daily and it can go weeks without use. Most journeys are long (2 hrs plus) and at motorway/fast A road speeds.
11th Jun 2023 5:29pm |
I'm not adverse to getting my fingers dirty re oil changes,I presume from the responses that these cars tell you when they want an oil change then as opposed to a yearly or mileage based change? |
11th Jun 2023 5:41pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1129 |
Yes , the miles to service due will drop. I think most of us on here will do an oil and filter change in between the yearly service. overfinch modified |
11th Jun 2023 9:34pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Only on the Adblue cars... The Adblue can dilute the engine oil if DPF fails to regen a number of times? Pre 16MY don't suffer this phenomenon sir... |
11th Jun 2023 11:04pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Am I right in thinking it is the “Adblue” models that are Euro 6 specification? 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
12th Jun 2023 7:46am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1416 |
@V8 Bob:
12th Jun 2023 8:22am |
Yes sir it is… |
12th Jun 2023 8:38am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Our 4.4 AdBlue L405 has been spot on but we have suffered with the oil dilution, it’s been no big deal though we have it serviced by LR each year and then do a mini at home service 6 months later.
12th Jun 2023 6:38pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3738 |
My last 4.4 V8 Diesel covered 77,000 miles absolutely faultlessly - no issues with Adblue / oil dilution at all. Service indicator came on religiously at 12 months with the annual mileage ranging between 9k and 15k miles. No early oil changes were needed.
12th Jun 2023 10:17pm |
Monty+4 Member Since: 25 Oct 2023 Location: Argyll Posts: 9 |
I would be very interested to know how add blue can dilute the oil as it is injected directly into the exhaust system? I have had an L493 and now have an L405 both with add blue. \dilution of the engine oil occurs in all diesel Landrover cars which have a dpf with or without add blue, it is extra fuel (diesel) which is injected into the engine to increase the exhaust temperature during regeneration which may result in oil dilution due to incomplete regeneration cycles. Nothing to do with adblue. |
17th Dec 2023 3:27pm |
