Home > Maintenance & Mods (L405) > deployable steps with deployable towbar?
28capridave
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Hi does anyone know if I can fit deployable sidesteps to my car which has a deployable towbar fitted, only asking as I've seen a couple of ads that state "not with deployable towbar"
Many thanks Dave
Post #666025 6th Jun 2023 4:04pm
Yes - I have both Thumbs Up
Post #666029 6th Jun 2023 4:46pm
28capridave
Thanks Alistair, but do you know why there seems to be a difference on the steps whether fitted with deployable towbar or not?
TRhanks Dave
Post #666035 6th Jun 2023 5:11pm
tomo141
I had factory deployable tow bar on my MY13 RR and retro fitted deployable sidesteps with no issues at all. The steps were plug and play.
My MY18 RR had factory deployable steps and i had a deployable tow bar retro fitted, no issues at all. The tow bar needed to be programmed as it works via the infotainment system as well as the button in the boot.
Tomo ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #666049 6th Jun 2023 8:24pm
Re: deployable steps with deployable towbar?
28capridave wrote:
... only asking as I've seen a couple of ads that state "not with deployable towbar"
I think the ads might be avoiding potential for "overpromising" as I think many, if not all, cars come with "towing preparation" and even "tow assist" as a standard part of the electronics, but the actual deployable towbar is an option.
Like Alastair, I have both. And there's only one type of deployable steps (and they're an option too!). Mike - MPx
Post #666052 6th Jun 2023 10:08pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Many thanks Dave
I seem to recall that upto MY17 use 2 seperate ecu's, one for steps and one for towbar (as my MY16.5 does, I added a towbar, with steps already fitted and needed to add the ecu for the bar). MY17 onwards uses a shared ecu for both, so I guess if you do not have steps then you would also need the shared ecu to be installed. I would assume if yours is MY17 onwards then you already have the shared ecu?
Hope this helps! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #666060 7th Jun 2023 5:38am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
I did hear from one company (Pegasus 4x4 I think) that fits deployable side steps (Not LR ones) that they use the feed for the deployable tow bar to power the side steps. So, if you fitted their side steps, you could not then fit a deployable tow bar without having to find another feed.
I have the factory fitted deployable side steps and deployable tow bar.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #666080 7th Jun 2023 10:03am
That sounds like a possibility.
All I can say is that genuine RR deployable steps work OK with a deployable tow bar.
Post #666091 7th Jun 2023 10:31am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The problem with Pegasus steps as opposed to JLR steps is that they do not supply a roof access switch which is fitted at knee level on cars from the years 2013-15 years after that it is from the info mat screen. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #666100 7th Jun 2023 11:52am
28capridave
Thanks, everyone for your input, the general consensus seems to be it's ok to do but I may have to possibly find an alternative feed..
Post #666126 7th Jun 2023 6:44pm
28capridave
Does anyone have a schematic they can send me at all?
Many thanks Dave
Post #666127 7th Jun 2023 6:45pm
Up on the top right of the page, under where it says fullfatrr.com, there's a link to the Wiki. There's a Workshop Manual there and it might have one - I haven't looked to check but it's useful to download anyway.
Post #666145 8th Jun 2023 6:24am
28capridave
Yes Alistair I've already downloaded the workshop manual and there doesn't appear to be anything mention of deployable steps it shows the deployable towbar also the wiki on the deployable steps shows the L322
Post #666150 8th Jun 2023 7:57am
These 2 threads seem to support what 4RRS was saying about earlier vs later cars. What year is yours ?
https://www.fullfatrr.com/forum/topic65044.html
https://www.fullfatrr.com/forum/topic62030.html
Post #666153 8th Jun 2023 8:34am
28capridave
Hi Alistair sorry for the delay mine is a MY14 so similar to yours, and those video links are spot on the only query I can see is the plug where the steps plug into as its the same plug I think as the towbar but if thats the case I dont use the towbar so can simply unplug the towbar and plug the steps in there unless you can point me in another direction power wise? also are the steps painted or rubber covered like the l322?
Many thanks Dave
Post #666536 13th Jun 2023 6:05pm
