![]() | Home > Technical (L322) > Brake pipe part numbers |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Really not worth buying genuine, you need to remove loads to fit as they are pre bent...
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Cheers, only asked because i had sub frame , exhaust and the trst of it off at the moment. Tbh there not too bad but just thought while i was in there woyld bebthevtime. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
They can be found under part No's in the Wiki file. |
j3fry Member Since: 23 Dec 2014 Location: Bedfordshire Posts: 59 ![]() ![]() ![]() |
I have done both of my l322 one a 2007 and the other a 2011 and the only difference is if you do the front ones on the 2011 you have to remove some plastic parts and get the Aircon drained but it’s not that hard to do them at all especially while you have the subframe out as I did mine with the subframe still fitted |
Hi I should have also said I purchased genuine pipes as it looks much more professional with all the correct bends |
