Home > Technical (L322) > Brake pipe part numbers
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Hi all would anyone happen to have part number for rear brake pipes for 2010 l322. Im after the ones that run down nearside before crossing over to rear. Not the flexible assembly one. Regards Mark.
Post #665496 30th May 2023 8:09pm
Really not worth buying genuine, you need to remove loads to fit as they are pre bent...
Much better off making new ones with a copper nickel alloy, last forever and you can bend them as needed to fit... Thumbs Up Pete
Post #665514 31st May 2023 9:07am
Landmark
Cheers, only asked because i had sub frame , exhaust and the trst of it off at the moment. Tbh there not too bad but just thought while i was in there woyld bebthevtime.
Post #665561 31st May 2023 3:00pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
They can be found under part No's in the Wiki file.
Post #665608 1st Jun 2023 9:30am
j3fry
Brake pipes
I have done both of my l322 one a 2007 and the other a 2011 and the only difference is if you do the front ones on the 2011 you have to remove some plastic parts and get the Aircon drained but it’s not that hard to do them at all especially while you have the subframe out as I did mine with the subframe still fitted
Post #665646 1st Jun 2023 5:34pm
j3fry
Brake pipes
Hi I should have also said I purchased genuine pipes as it looks much more professional with all the correct bends
Post #665647 1st Jun 2023 5:37pm
