![]() | Home > Technical (L322) > Removing front door lock actuator L322 MY2012 |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 ![]() ![]() ![]() |
Disregard my last. It is a very straight-forward job and doesn't involve window channels at all.
DaveM06 Member Since: 30 May 2023 Location: Quantico USA Posts: 3 ![]() ![]() ![]() |
Hi,
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
loose 4 bolts, remove cables. reinstall in oposite direction. |
As Jimmie says, once you have removed the door card, remove the bolts (3 or 4) from the door latch at the trailing edge of the door. You will be able to then reach inside the door and remove the latch mechanism. It has the actuator cable attached and the mechanical door handle cable. You will need to remove both, plus the rod leading to the door button/knob above. You’ll need to swap the cover from your old unit to the new one and then refitting is a reversal of removal. The part (for the MY12) is only available from LR and will cost you around £250-£300. I don’t recall the part number, however LR can help. |
Jimmie, Stoutgoose, many thanks!
