![]() | Home > Technical (L322) > B1195-87 Passengers Side Frontal Acceleration Sensor |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I believe it’s behind the front wing. Access from outside by taking the side vent off.
InlovewithRR Member Since: 20 May 2023 Location: London Posts: 13 ![]() ![]() ![]() |
Thanks,will take alook. Side vent you mean the grille just nehind front wheel? |
Just an update. Sensors behind vents are called vertical acceleration sensor. And faults given are C101D-14 and C101E-14
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
I think you will find it is item 4 in the following section of the WM in the Wiki.
I must be daft but where is wm in wiki? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Attached to the slam panel bottom of headlights iirc |
Workshop manual (WM) for 2010-2012 is under the downloads. This is a link direct.
Sorry if I gave wrong location then. Thought that’s all there were.
Thank you everybody. Its straight below headlight. cant understand how i couldnt see it(probably too much stress |
Gald to hear that.
