Home > Technical (L322) > B1195-87 Passengers Side Frontal Acceleration Sensor
InlovewithRR
United Kingdom 2012 Range Rover HSE 4.4 V8 Bonatti Grey
Hi,
Got fault B1195-87 Passengers Side Frontal Acceleration Sensor
Anybody could tell me the location of this sensor 2012 Range rover 4.4 tdv8
Thank you very much!
Post #665253 27th May 2023 8:32pm
mjdronfield
I believe it’s behind the front wing. Access from outside by taking the side vent off.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #665255 27th May 2023 8:57pm
InlovewithRR
Thanks,will take alook. Side vent you mean the grille just nehind front wheel?
Post #665275 28th May 2023 8:26am
InlovewithRR
Just an update. Sensors behind vents are called vertical acceleration sensor. And faults given are C101D-14 and C101E-14
They give adaptive dynamics fault as well. Maybe will be useful for somebody. I need to find passenger side frontal acceleration sensor.
Fault code B1195-87
Post #665285 28th May 2023 10:37am
rjff
I think you will find it is item 4 in the following section of the WM in the Wiki.
It looks to be in an area behind the passenger headlight.
Search route:
Wiki
Wm2010-2012
Automatic transmission and transaxle
Body and paint
SRS
Pretensioners location
see Item4 on diagram
HTH Cheers
Richard
Gap IIDBT
Post #665291 28th May 2023 11:44am
InlovewithRR
I must be daft but where is wm in wiki?
Post #665293 28th May 2023 11:56am
dingg1
Attached to the slam panel bottom of headlights iirc
Post #665295 28th May 2023 12:23pm
rjff
Workshop manual (WM) for 2010-2012 is under the downloads. This is a link direct.
https://drive.google.com/file/d/0Byv5LFgQZ...yXSlJt_k7A
Download it as a PDF.
Have a search where dingg1 says, not sure what, if anything may need removing for access. Cheers
Richard
Gap IIDBT
Post #665297 28th May 2023 12:42pm
mjdronfield
Sorry if I gave wrong location then. Thought that’s all there were.
Maybe there are other sensors for the DSC etc then.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #665341 28th May 2023 10:15pm
InlovewithRR
Thank you everybody. Its straight below headlight. cant understand how i couldnt see it(probably too much stress Very Happy All sorted now
Post #665388 29th May 2023 1:02pm
rjff
Gald to hear that.
What was the solution, may help others in future? Cheers
Richard
Gap IIDBT
Post #665392 29th May 2023 1:19pm
