Home > Maintenance & Mods (L322) > Can anyone name this or give me part numbers?
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
Doing a few checks today, topped up coolant tank and sprayed a little GT85 onto some bolts on the slam panel that were a little rusted. Also cleaned the engine cover and airbox covers.
At the back corner on either side, just at the bottom of the A pillar, their is a sculpted high density foam block. Presumably it is to either reduce wind noise. This is it in the picture. I'd like to replace them as they are just a bit past their best with age. Any assistance appreciated.
Post #665328 28th May 2023 7:20pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
LR023475 Insulator, RH, Lower BH42 16E096-AB
LR023474 Insulator, LH, Lower BH42 16E097-AB
Post #665331 28th May 2023 8:08pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
See this prior discussion also; https://www.fullfatrr.com/forum/post655058.html#655058 TDV8 4.4 2012
Post #665332 28th May 2023 8:10pm
Proftinkerpot
Thanks Jimmie
That is fantastic.
Hopefully I can find these somewhere now I have part numbers.
Post #665333 28th May 2023 8:11pm
Bingo_123
Anyone has part no's for the similar foam panels under the rear doors plastic panel, where the rear wheel arches start.
Thanks
Post #665347 29th May 2023 6:39am
jimmie
i bet you looking for
LR012481 Insulator - Wheelhouse, RH AH42 11418-AA
LR012482 Insulator - Wheelhouse, LH AH42 11419-AA
or
LR011730 Insulator, RH AH42 108B00-AA
LR011731 Insulator, LH AH42 108B00-BA
Post #665377 29th May 2023 11:27am
Bingo_123
thanks Jimmie
Post #665932 5th Jun 2023 8:16am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Completely removed mine, no discernible difference in wind noise and they are a moisture trap. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #665938 5th Jun 2023 10:14am
