![]() | Home > Maintenance & Mods (L322) > Coolant Change TDV8 After Oil Cooler Fix |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
There is nothing special with coolant change, just old out and new in. Air bleeding will happens by itself.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1407 ![]() ![]() |
Whilst maybe slightly different than the L322, on my L405 I missed out a stage which prevented the refill going properly and air lock occurring.
PaulCee Member Since: 31 Oct 2014 Location: UK Posts: 18 ![]() |
Thank you guys for the answers and help.
Yes, just dont use Webasto straight away after fluid change couple hours. If you do it, changeover valve will close and separate circuit and not let new fluid in. In other case this will take care of itself over short time.
Jaguar3, wow that is very useful, certainly above and beyond, very much appreciated.
Same time you can clean additional radiator as well.
I never knew about that Aux rad so when I was down the jetwash yesterday I directed the pressure hose through the gap around the lower fog light and back through the vents in the wheel liner. I suspect it's not needed unless you are towing or operating in very hot climates though. 2012 TDV8 Vogue (L322) |
I think its for highway and high speed in hot conditions of course. Anyway its not working during normal driving due there is not much air flow. Just a small gap around the fog light only.
