Home > Maintenance & Mods (L322) > 2010-2012 Front Grill Removal - What am I missing?
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
It was a simple task on the old 2008 3.6 Vogue, but I'm a bit stumped with this 2012 one....
Three small bolts with crosshead slots, two vertical bolts on the slam panel and one horizontal in the middle of the grill. Grill comes away from the body at the top edge, pulls forward slightly and then I expected it just to pull upwards and away..... Nope!
Pulling upwards at an angle away from the car as hard as I dare and the whole car body starts to move upwards on the suspension! Shocked
What am I missing??? Confused
There's no access to anything that might be a fixing at the bottom of the grill, or do I need to remove the whole front bumper to reveal more screws (surely not)? Sad
Have searched the forum for ideas without success - all I could find were posts about fitting the later grill to earlier cars.
HELP! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #665029 25th May 2023 2:26pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Try pulling forwards, not upwards.
Last time I used gloves as I put my fingers through the grill at the lowest possible points.
Start at the edges. 2012 4.4TDV8
2000 Honda S2000
Post #665033 25th May 2023 2:46pm
put something on the bumper so you dont scratch it... ... - .- -.
Post #665038 25th May 2023 3:05pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I use a large flat bladed screwdriver to lever where the two lower ‘lugs’ locate into their holders, a twisting action usually pops them out without needing to pull on the grille itself (which if not careful, can detach from the grille frame as it’s only plastic welded together). Jonathan
2007 Defender 90 XS Hardtop
Post #665042 25th May 2023 4:28pm
JMC
So, for anyone else with a 2010-2012, the grill comes off at the bottom horizontally - nothing like the previous model at all.
There are actually four push-fit lugs on the bottom of the grill. Once the top three bolts are undone, just pull the grill directly away horizontally. Needless to say, a degree of care is required and as Stan has said above, place a tea-towel between the grill and the bumper to avoid scratches.
Post #665067 25th May 2023 7:34pm
