Home > Wheels & Tyres > Going to order 5 new tyres this week
EOD Steve
United Kingdom 2012 Range Rover Vogue TDV8 Sumatra Black
As per title..........
Just because they look cool, I was going for some AT tyres from either General, Wildpeak or Cooper.
But can you convince me otherwise and sticking with Pirelli?
If so, which model?
Usage: Travelling mainly on roads as my daily driver. Overland trek into the Peaks / Lakes / Cairngorms this summer. Occasional track / grass / campsite terrain. Nothing even remotely serious or even semi serious.....
Can either stick with 255/50/20 as fitted (Pirelli Zeros) or was thinking 275/45/20 in any of the above AT......
Your more experienced views very welcome....
Steve 4.4 TDV8 Sumatra Black + Ivory Leather
Post #664786 23rd May 2023 2:20pm
You won't need an A/T tyre to do what you plan, the only issue is muddy side slopes where you may slip sideways on road tyres but it doesn't sound like you will be doing anything like that...
A/T tyres are noisier than road tyres, they also reduce MPG, and are worse at road holding and braking on wet or dry roads...
IMHO not really a tyre of choice unless you really need the extra off road ability... Thumbs Up
I'm sure you will get lots more views... Pete
Post #664788 23rd May 2023 2:59pm
I completely agree with Pete, unless you really need the extra off road performance, there are more down sides with AT's as a road tyre.
Also worth looking at 255/55/20 tyres if you're replacing all 5. A lot of people have made the switch - its a standard tyre on the L405 and seems a good bit cheaper than the 50's
Post #664796 23rd May 2023 3:43pm
PeteT80
I’m running General Grabber AT3s 255/55/20 and no more road noise than Pirelli Scorpions.
Post #664798 23rd May 2023 3:45pm
EOD Steve
Will 55's effect the rolling speed in any way mate?
s 4.4 TDV8 Sumatra Black + Ivory Leather
Post #664799 23rd May 2023 3:48pm
your speedo will be spot on. ... - .- -.
Post #664800 23rd May 2023 4:14pm
EOD Steve
OK thank you....... 4.4 TDV8 Sumatra Black + Ivory Leather
Post #664801 23rd May 2023 4:15pm
EOD Steve
OK so going away from ATs altogether, what about...
Pirelli Scorpion Zero Asimmetrico PNCS?
£218 each at a local shop......?????? 4.4 TDV8 Sumatra Black + Ivory Leather
Post #664802 23rd May 2023 4:18pm
JayGee
You may not need all terrain tyres but all season tyres are a very worthwhile choice for UK roads. 2012 TDV8 Vogue (L322)
Post #664811 23rd May 2023 5:55pm
Vogue
If you are using your RR off road in muddy, greasy fields particularly in the winter then get the AT’s, if not don’t bother. A RR is extremely capable on standard tyres, however tread clogged with mud will stop even a tractor.
I’ve got two sets of tyres - Cooper AT’s in 285/50/20 for the winter shooting season - November to
January inclusive - the rest of the year standard tyres 275/40/22’s are fine - even during the wetter September /October months off road. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #664822 23rd May 2023 6:57pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
My tuppence… I wanted to go a little larger in tyres last year and wanted a more rugged A/T look.
Ended up opting for these Yokohama Geolanders: https://www.camskill.co.uk/m63b5388s13299p...se%3A_72dB
Can only say I’m very happy with the look and the drive with them Thumbs Up Did have a slight rub on full lock in reverse but a bit of minor liner fettling sorted that. Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #664907 24th May 2023 12:43pm
EOD Steve
I think I now agree with you mate, so thank you for all your continuing advice ( you have advised me on other L322 bits and pieces so thanks).
I happened across Pirelli Scorpion Zero Assimetrico PNCS. They have an 'A' noise rating (69db) and a 'B' rating for wet weather. Can't find a decent review online anywhere?
Anyone running the above tyres? 4.4 TDV8 Sumatra Black + Ivory Leather
Post #664932 24th May 2023 4:35pm
half a dozen threads down theres a discussion re these.. ... - .- -.
Post #664937 24th May 2023 4:54pm
EOD Steve
Thanks Stan will check them out ! 4.4 TDV8 Sumatra Black + Ivory Leather
Post #664939 24th May 2023 5:12pm
DrRob
I do 99% on road but still chose 255 55 20 in General Grabber AT3 for price point and they look god too 😂
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #664957 24th May 2023 8:17pm
