Home > Technical (L322) > 2010-2012 o/s/f LED sidelights not working |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 774 |
A few days ago I noticed my drivers side front LED sidelamps were flickering a bit. Now they are not working at all. Headlamps (dipped/beam) are OK and all the other sidelights are fine.
22nd May 2023 1:47pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 |
I think you will find they are non serviceable LED's you have to change the whole light unit...
22nd May 2023 9:49pm |
Well that's not happening....... The older I get, the more I realise that people confuse wrinkles for wisdom |
23rd May 2023 8:04am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 |
unusual for these led lights to fail...i would double check the connectors and the wiring around the light unit.. ... - .- -.
23rd May 2023 8:44am |
Was told today that sidelights are part of the MoT, so this is now becoming a priority. Can't believe I'm the only person to have suffered an LED failure in the last decade. It's not just one of the LED's, it's all of them in the headlamp unit. Also find it odd that, with all the electronic gizmo's in the late L322's, there's nothing on the display to say there's a bulb failure. The older I get, the more I realise that people confuse wrinkles for wisdom |
24th May 2023 8:35pm |
I take it you have tried the usual fuses... there can be more than one in a system... Pete
24th May 2023 9:30pm |
Yes, fuses are fine.
25th May 2023 5:38am |
Good luck... Pete
25th May 2023 6:19am |
The plot thickens.....
25th May 2023 7:43pm |
Posting an update here in case anyone in future suffers the same issue.
24th Jun 2023 9:46pm |
Not a bodge, just a slight modification... Pete
24th Jun 2023 11:38pm |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 60 |
JMC
13th Jan 2025 12:41pm |
As I said a few posts back, I made a 'slight modification'........ That's a technical term for inadvertently breaking off the lower mounting points! The older I get, the more I realise that people confuse wrinkles for wisdom |
13th Jan 2025 6:32pm |
I assume when you refitted them, the top accessible mounting points hold them securely and there is no movement/flexing when you are driving down the road. -----------------------
14th Jan 2025 4:50pm |
