Home > Technical (L405) > One problem solved another one started ? Dpf and P040D-00
Jecks111
Ok so my juddering when slowly pulling out of Junctions problem seems to be solved with a double flush of the transfer case.
I was 100 yards from home and a dpf amber light came on.
I'm Getting the following 2 Permanent codes pictured below
P040D-00
P2459-65
Where should I start ?
Cheers.
Post #664562 20th May 2023 10:17pm
P040D I have covered on here. It means your temp sensor in the passenger side manifold is kaput! This can lead to overfueling and premature DPF filling sir… 👍
Post #664565 20th May 2023 11:11pm
Jecks111
Thanks. Had a good search and read
A removal of the fuel filter then somehow try to reach the sensor down there looks fun.
I Wonder can a small hand fit down there or is it 3 socket extensions etc
One for next week.
Post #664572 21st May 2023 12:42am
Jecks111
Is there a special tool needed to refit that sensor?
Are you able to reach down without the multi extension socket pictured from a previous post
Post #664613 21st May 2023 2:24pm
