![]() | Home > Technical (L322) > no low range TD6 |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 ![]() ![]() ![]() |
Does anyone have any suggestions......
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
You could use fuse 37 to put the transfer box in Neutral (providing you’re on the flat and the handbrake works). This would at least confirm that the shift motor and rotary potentiometer are functioning. Do you suspect that it might be the switch itself at fault?
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
So what exactly does it do when you try to select low range? Is it trying to change? Does it do anything at all? |
RRPhil,
RRPhil,
Have you tried googling the problem ... seems to be suggestions that the problem might be electrical rather than mechanical, so replacing the transfer case may not help. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
Garry, did you see my reply on AULRO? Ron B. VK2OTC
Just ignoring any indication on the dashboard for a moment, can you hear the shift motor moving when you insert fuse 37? Does the transfer box, in fact, go into neutral i.e. will the car roll even in Park? You need to determine if the problem is with the switch, the shift motor (e.g. potentiometer), possibly the ECU, or a mechanical issue. You just need to go through a process of elimination. Phil |
“Noise on actuator signal” is the usual diagnostic fault code for the potentiometer, sometimes together with an output speed signal error.
I had both symptoms with mine and it did have cracked solder joints in the potentiometer. Ron B. VK2OTC
Had to go down the shops,when I got back I parked on a bit of a slope.
To be honest and being the cheapskate that I am, I’d check the potentiometer first.
Mechanically the NV225 is pretty robust. I would certainly try swapping over the shift motors (just 3 bolts) before resorting to replacing the whole transfer case.
