![]() | Home > Technical (L405) > Steering judder when turning out of junctions at low speed |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
Have you tried putting your Terrain Response into manual mode - with the button up? I had exactly this with my last L405, and it stopped as soon as I put it into manual, it seems that a hard lock pulling out of a junction and applying power caused this issue - totally solved in manual - or keep the button down and just live with it 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Jecks111 Member Since: 06 Apr 2023 Location: Uk Posts: 19 ![]() ![]() |
Thanks. Ive Just been out there and unfortunately it's still the same. Any ideas what could be causing this? |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
That front lower arm - yes you can move it with your hand. The large bush has quite a bit of give.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
It`s almost certainly the rear diff, but only if you have a lockable rear, the rear has a clutch pack that requires the oil flushed and refilled, which should be done when serviced.
So I had the chance earlier today to get into a car park and replicate me pulling out from junctions, both left and right , I hope on one was watching, it's definitely a thumping , juddering sound until I've straightened or nearly straightened up. Roughly from half lock on.
Worth doing a transfer case double flush and clutch calibration by the sounds of it. I had the same issue and it ended up resolving the symptom for a couple of weeks only. I did this three times and each time was the same whereby the problem reared its head after a couple of weeks.
Hopefully getting the special oil tomorrow at some point, if not then it will be Monday. Called on the way past Land Rover today and got a couple of the copper washers for the hex nuts.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Prepare for a world of fun doing those arms. The ball joints are tapered into a steel sleeve in the aluminium hub
Double flush of the transfer case seems to have solved the juddering. Only got to try a few turns earlier but seems to have solved it. . Fingers crossed |
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 67 ![]() ![]() ![]() |
Hi Jecks what was the final result? Did the low speed knock go away? I have just started to get exactly the same symptom on mine. My local Indy tells me its the clutch pack inside the transfer case that is worn (I had hoped it was the propshaft center bearing) |
Hi. Yea the double flush cured that problem, though shortly after i had further problems and developed an engine oil leak or 2 and decided to move it on as was out of LR warranty. |
